Datasheet CMHZ5221B - CMHZ5267B (Central Semiconductor) - 2
Description500mW Surface mount Diode-Zener Single in SOD-123 package
Pages / Page3 / 2 — CMHZ5221B THRU CMHZ5267B. SURFACE MOUNT. SILICON ZENER DIODE. 2.4 VOLTS …
File Format / SizePDF / 408 Kb
CMHZ5221B THRU CMHZ5267B. SURFACE MOUNT. SILICON ZENER DIODE. 2.4 VOLTS THRU 75 VOLTS. 500mW, 5% TOLERANCE
CMHZ5221B THRU CMHZ5267B SURFACE MOUNT SILICON ZENER DIODE 2.4 VOLTS THRU 75 VOLTS 500mW, 5% TOLERANCE
CMHZ5221B THRU CMHZ5267B SURFACE MOUNT SILICON ZENER DIODE 2.4 VOLTS THRU 75 VOLTS 500mW, 5% TOLERANCE ELECTRICAL CHARACTERISTICS:
(TA=25°C), VF=0.9V MAX @ IF=10mA (for all types)
ZENER TEST MAXIMUM ZENER MAXIMUM MAX. MARKING VOLTAGE CURRENT IMPEDANCE REVERSE TEMP. CODE TYPE VZ @ IZT CURRENT COEFF. MIN NOM MAX IZT ZZT@IZT ZZK @ IZK IR @ VR
Θ
VZ V V V mA Ω Ω mA µA V %/°C
CMHZ5254B 25.65 27 28.35 4.6 41 600 0.25 0.1 21 +0.090 CK4 CMHZ5255B 26.60 28 29.40 4.5 44 600 0.25 0.1 21 +0.091 CK5 CMHZ5256B 28.50 30 31.50 4.2 49 600 0.25 0.1 23 +0.091 CM1 CMHZ5257B 31.35 33 34.65 3.8 58 700 0.25 0.1 25 +0.092 CM2 CMHZ5258B 34.20 36 37.80 3.4 70 700 0.25 0.1 27 +0.093 CM3 CMHZ5259B 37.05 39 40.95 3.2 80 800 0.25 0.1 30 +0.094 CM4 CMHZ5260B 40.85 43 45.15 3.0 93 900 0.25 0.1 33 +0.095 CM5 CMHZ5261B 44.65 47 49.35 2.7 105 1000 0.25 0.1 36 +0.095 CN1 CMHZ5262B 48.45 51 53.55 2.5 125 1100 0.25 0.1 39 +0.096 CN2 CMHZ5263B 53.20 56 58.80 2.2 150 1300 0.25 0.1 43 +0.096 CN3 CMHZ5264B 57.00 60 63.00 2.1 170 1400 0.25 0.1 46 +0.097 CN4 CMHZ5265B 58.90 62 65.10 2.0 185 1400 0.25 0.1 47 +0.097 CN5 CMHZ5266B 64.60 68 71.40 1.8 230 1600 0.25 0.1 52 +0.097 CP1 CMHZ5267B 71.25 75 78.75 1.7 270 1700 0.25 0.1 56 +0.098 CP2 Higher Zener voltages may be available upon request. Please consult factory.
SOD-123 CASE - MECHANICAL OUTLINE LEAD CODE:
1) Cathode 2) Anode R10 (18-January 2024)
www.centra lsemi.com
