Datasheet TEA5767HN (NXP) - 3
| Manufacturer | NXP |
| Description | Low-power FM stereo radio for handheld applications in 40-VFQFN Exposed Pad package |
| Pages / Page | 40 / 3 — NXP Semiconductors. TEA5767HN. Low-power FM stereo radio for handheld … |
| File Format / Size | PDF / 201 Kb |
NXP Semiconductors. TEA5767HN. Low-power FM stereo radio for handheld applications. Table 1. Quick reference data. Symbol
NXP Semiconductors TEA5767HN Low-power FM stereo radio for handheld applications Table 1. Quick reference data
…continued VCCA = VCCD = VCC(VCO) = 2.7 V; Tamb = 25 °C; AC values are given in RMS; for VRF the emf value is given; unless otherwise specified.
Symbol Parameter Conditions Min Typ Max Unit
(S+N)/N maximum signal plus VRF = 1 mV; L = R; 54 60 - dB noise-to-noise ratio ∆f = 22.5 kHz; fmod = 1 kHz; de-emphasis = 75 µs; BAF = 300 Hz to 15 kHz αcs(stereo) stereo channel VRF = 1 mV; R = L = 0 or R = 0 24 30 - dB separation and L = 1 including 9 % pilot; ∆f = 75 kHz; fmod = 1 kHz; data byte 3 bit 3 = 0; data byte 4 bit 1 = 1 THD total harmonic VRF = 1 mV; L = R; - 0.4 1 % distortion ∆f = 75 kHz; fmod = 1 kHz; de-emphasis = 75 µs [1] VCCA, VCC(VCO) and VCCD must not differ by more than 200 mV. [2] Low side and high side selectivity can be switched by changing the mixer from high side to low side LO injection.
4. Ordering information Table 2. Ordering information Type number Package Name Description Version
TEA5767HN HVQFN40 plastic thermal enhanced very thin quad flat package; SOT618-1 no leads; 40 terminals; body 6 × 6 × 0.85 mm TEA5767HN_5 © NXP B.V. 2007. All rights reserved.
Product data sheet Rev. 05 — 26 January 2007 3 of 40
Document Outline 1. General description 2. Features 3. Quick reference data 4. Ordering information 5. Block diagram 6. Pinning information 6.1 Pinning 6.2 Pin description 7. Functional description 7.1 Low-noise RF amplifier 7.2 FM mixer 7.3 VCO 7.4 Crystal oscillator 7.5 PLL tuning system 7.6 RF AGC 7.7 IF filter 7.8 FM demodulator 7.9 Level voltage generator and analog-to-digital converter 7.10 IF counter 7.11 Soft mute 7.12 MPX decoder 7.13 Signal dependent mono to stereo blend 7.14 Signal dependent AF response 7.15 Software programmable ports 7.16 I2C-bus and 3-wire bus 8. I2C-bus, 3-wire bus and bus-controlled functions 8.1 I2C-bus specification 8.1.1 Data transfer 8.1.2 Power-on reset 8.2 I2C-bus protocol 8.3 3-wire bus specification 8.3.1 Data transfer 8.3.2 Power-on reset 8.4 Writing data 8.5 Reading data 9. Internal circuitry 10. Limiting values 11. Thermal characteristics 12. Static characteristics 13. Dynamic characteristics 14. FM characteristics 15. I2C-bus characteristics 16. Test information 17. Package outline 18. Soldering 18.1 Introduction to soldering 18.2 Wave and reflow soldering 18.3 Wave soldering 18.4 Reflow soldering 19. Revision history 20. Legal information 20.1 Data sheet status 20.2 Definitions 20.3 Disclaimers 20.4 Trademarks 21. Contact information 22. Contents
