Datasheet TCKE6 (Toshiba) - 4
| Manufacturer | Toshiba |
| Description | 40 V, 2.5 A eFuse IC with Adjustable Overcurrent Protection in TSOP6F package |
| Pages / Page | 26 / 4 — 5. Pin Description. Table 5.1 Pin Description. PIN Name. Description. 6. … |
| File Format / Size | PDF / 1.4 Mb |
5. Pin Description. Table 5.1 Pin Description. PIN Name. Description. 6. Operation Logic Table. Table 6.1 Operation Logic Table
TCKE6 Series
5. Pin Description Table 5.1 Pin Description PIN Name Description
Enable input. Active high. EN This function turns on the output as an enable signal. Current limit set input. A resistor between ILIM terminal and GND sets the current limit. ILIM Please do not apply external voltage FLAG Open drain signal output. Outputs the status of a specific protection operation. MODE switching. MODE The fault response is auto-retry type at high input. When the input is low or open, the fault response is latch type. VIN Supply input. Input the power switch and the supply voltage for the device. GND Ground VOUT Output. Output of the power switch.
6. Operation Logic Table Table 6.1 Operation Logic Table
TCKE601RA, TCKE601RL, TCKE602RM (Ta = -40 to 125ºC) VIN ≤ VIN_UVLO (Note 3) VIN_UVLO < VIN < VIN_OVLO VIN_OVLO ≤ VIN (Note 4) Output OFF ON OFF TCKE603RA, TCKE603RL (Ta = -40 to 125ºC) VIN ≤ VIN_UVLO (Note 3) VIN_UVLO < VIN < VIN_OVLO VIN_OVLO ≤ VIN (Note 4) EN = Low level OFF OFF OFF Output EN = High level OFF ON OFF Note3:The UVLO threshold has hysteresis, so please refer to the operation description for details. Note4:The OVLO threshold has hysteresis, so please refer to the operation description for details. © 2 025 4 2025-10-28 Toshiba Electronic Devices & Storage Corporation Rev. 4.0
