Datasheet SB520, SB530, SB540, SB550, SB560 (Vishay)
ManufacturerVishay
DescriptionSchottky Barrier Plastic Rectifier in DO-201AD package
Pages / Page4 / 1 — SB520 thru SB560. Schottky Barrier Rectifier. FEATURES. DO-201AD. TYPICAL …
File Format / SizePDF / 69 Kb
SB520 thru SB560. Schottky Barrier Rectifier. FEATURES. DO-201AD. TYPICAL APPLICATIONS. PRIMARY CHARACTERISTICS
Datasheet SB520, SB530, SB540, SB550, SB560 Vishay
SB520 thru SB560
Vishay General Semiconductor
Schottky Barrier Rectifier FEATURES
• Guardring for overvoltage protection • Extremely fast switching • Low forward voltage drop • High forward surge capability • High frequency operation • Solder dip 275 °C max. 10 s, per JESD 22-B106
DO-201AD
• Compliant to RoHS directive 2002/95/EC and in accordance to WEEE 2002/96/EC
For use in low voltage high frequency inverters, freewheeling, dc-to-dc converters, and polarity protection
applications. IF(AV) 5.0 A VRRM 20 V to 60 V
MECHANICAL DATA Case:
I DO-201AD FSM 220 A Molding compound meets UL 94 V-0 flammability rating VF 0.48 V, 0.65 V Base P/N-E3 - RoHS compliant, commercial grade TJ max. 150 °C
Terminals:
Matte tin plated leads, solderable per J-STD-002 and JESD 22-B102 E3 suffix meets JESD 201 class 1A whisker test
Polarity:
Color band denotes the cathode end
MAXIMUM RATINGS
(TA = 25 °C unless otherwise noted)
PARAMETER SYMBOL SB520 SB530 SB540 SB550 SB560 UNIT
Maximum repetitive peak reverse voltage VRRM 20 30 40 50 60 V Maximum RMS voltage VRMS 14 21 28 35 42 V Maximum DC blocking voltage VDC 20 30 40 50 60 V Maximum average forward rectified current I at 0.375" (9.5 mm) lead length (fig. 1) F(AV) 5.0 A Peak forward surge current, 8.3 ms single half I sine-wave superimposed on rated load FSM 220 A Operating junction temperature range TJ - 65 to + 150 °C Storage temperature range TSTG - 65 to + 150 °C
ELECTRICAL CHARACTERISTICS
PARAMETER TEST CONDITIONS SYMBOL SB520 SB530 SB540 SB550 SB560 UNIT
Maximum instantaneous 5.0 A V forward voltage F (1) 0.48 0.65 V Maximum instantaneous TA = 25 °C 0.5 reverse current at rated IR (1) mA DC blocking voltage TA = 100 °C 50 25
Note
(1) Pulse test: 300 μs pulse width, 1 % duty cycle Document Number: 88721 For technical questions within your region, please contact one of the following: www.vishay.com Revision: 19-Oct-09 DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com 1
