Datasheet MBRS240L (ON Semiconductor)
| Manufacturer | ON Semiconductor |
| Description | Schottky Power Rectifier, Surface Mount, 2.0 A, 40 V in 403A-03 package |
| Pages / Page | 6 / 1 — DATA SHEET. www.onsemi.com. SCHOTTKY BARRIER. RECTIFIER. 2.0 AMPERES, 40 … |
| File Format / Size | PDF / 179 Kb |
DATA SHEET. www.onsemi.com. SCHOTTKY BARRIER. RECTIFIER. 2.0 AMPERES, 40 VOLTS. SMB Power Surface Mount Package. SMB. CASE 403A
DATA SHEET www.onsemi.com
Surface Mount
SCHOTTKY BARRIER
RECTIFIER 2.0 AMPERES, 40 VOLTS SMB Power Surface Mount Package
MBRS240LT3G, NRVBS240LT3G, NRVBS240LN
SMB CASE 403A
These devices employ the Schottky Barrier principle in a metal−to−silicon power rectifier. Features epitaxial construction with oxide passivation and metal overlay contact. Ideally suited for low
MARKING DIAGRAM
voltage, high frequency switching power supplies; free wheeling diodes and polarity protection diodes. AYWW 2BL4G
Features
G • Compact Package with J−Bend Leads Ideal for Automated Handling • Highly Stable Oxide Passivated Junction 2BL4 = Specific Device Code • Guard−Ring for Overvoltage Protection A = Assembly Location** • Low Forward Voltage Drop Y = Year WW = Work Week • ESD Ratings: G = Pb−Free Package ♦ Human Body Model = 3B (> 16000 V) (Note: Microdot may be in either location) ♦ Machine Model = C (> 400 V) • **The Assembly Location code (A) is front side NRVB Prefix for Automotive and Other Applications Requiring optional. In cases where the Assembly Location is Unique Site and Control Change Requirements; AEC−Q101 stamped in the package bottom (molding ejecter pin), Qualified and PPAP Capable* the front side assembly code may be blank. • These are Pb−Free Devices
Mechanical Characteristics ORDERING INFORMATION
• Case: Molded Epoxy
Device Package Shipping
† • Epoxy Meets UL 94 V−0 @ 0.125 in MBRS240LT3G SMB 2,500 / • Weight: 95 mg (Approximately) (Pb−Free) Tape & Reel • Cathode Polarity Band NRVBS240LT3G* SMB 2,500 / • Maximum Temperature of 260°C/10 Seconds for Soldering (Pb−Free) Tape & Reel • Finish: All External Surfaces Corrosion Resistant and Terminal NRVBS240LNT3G* SMB 2,500 / (Pb−Free) Tape & Reel Leads are Readily Solderable †For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specifications Brochure, BRD8011/D. © Semiconductor Components Industries, LLC, 2013
1
Publication Order Number:
January, 2020 − Rev. 9 MBRS240LT3/D
