Datasheet DS1000Z-E Series (Rigol) - 4
ManufacturerRigol
DescriptionDigital Oscilloscope
Pages / Page8 / 4 — RIGOL Probes and Accessories Supported by DS1000Z Series. RIGOL Passive …
File Format / SizePDF / 796 Kb
RIGOL Probes and Accessories Supported by DS1000Z Series. RIGOL Passive Probes. RIGOL Active & Current Probes. RIGOL
RIGOL Probes and Accessories Supported by DS1000Z Series RIGOL Passive Probes RIGOL Active & Current Probes RIGOL
Model Number Type Description Model Number Type Description BW: DC to 300 kHz 1X: DC to 35 MHz Max. input High Z 10X: DC to 150 MHz Current DC: ±100 A, Probe Compatibility: all
RIGOL
Probe AC P-P: 200 A, scopes. AC RMS: 70 A Compatibility: all
RIGOL
scopes. PVP2150 RP1001C BW: DC to 1 MHz Max. input 1X: DC to 20 MHz HighZ Current DC: ±70 A, 10X: DC to 150 MHz Compatibility: all
RIGOL
Probe AC P-P: 140 A, Probe scopes. AC RMS: 50 A RP1002C Compatibility: all
RIGOL
scopes. PVP3150 BW: DC to 50 MHz Max. input 1X: DC to 35 MHz Current AC P-P: 50 A (Noncontinuous), High Z 10X: DC to 350 MHz Probe AC RMS: 30 A Compatibility: all
RIGOL
scopes. Probe Compatibility: Must order RP1000P power all
RIGOL
scopes. RP1003C supply. BW: DC to 100 MHz PVP2350 Max. input Current AC P-P: 50 A (Noncontinuous), Probe AC RMS: 30 A DC to 500 MHz Compatibility: all
RIGOL
scopes. High Z Compatibility: Must order RP1000P power Probe all
RIGOL
scopes. RP1004C supply. BW: DC to 10 MHz RP3500A Max. input AC P-P: 300 A (Noncontinuous), Current 500 A (@pulse width ≤30 us), Probe AC RMS: 150 A DC to 300 MHz Compatibility: all
RIGOL
scopes. High CAT I 2000 V (DC+AC), Must order RP1000P power RP1005C supply. Voltage CAT II 1500 V (DC+AC) Probe Compatibility: all
RIGOL
scopes. Power Power supply for RP1003C, Supply RP1004C and RP1005C, support RP1300H 4 channels. RP1000P DC to 40 MHz High DC: 0 to 10 kV DC, High Voltage AC: pulse ≤20 kVp-p, Voltage BW: 25 MHz Probe AC: sine wave ≤7 kVrms Differential Max. Voltage ≤1400 Vpp Compatibility: all
RIGOL
RIGOL
scopes. scopes. RP1010H RP1025D High DC to 150 MHz Voltage BW: 50 MHz High DC+AC Peak: 18 kV CAT II Differential Max. Voltage ≤7000 Vpp Voltage AC RMS: 12 kV CAT II Probe Compatibility: all
RIGOL
scopes. Probe Compatibility: all
RIGOL
scopes. RP1050D RP1018H High Voltage BW: 100 MHz Max. Voltage ≤7000 Vpp 50 Ω impedance Differential Adapter Compatibility: all
RIGOL
scopes. adapter (2 W, 1 GHz) Probe RP1100D RT50J 4
