Datasheet LTC6754 (Analog Devices) - 22
| Description | High Speed Rail-to-Rail Input Comparator with LVDS Compatible Outputs |
| Pages / Page | 22 / 22 — Typical applicaTion. 15 Bit PRBS 250Mbps Logic Signal to LVDS Converter … |
| File Format / Size | PDF / 1.6 Mb |
Typical applicaTion. 15 Bit PRBS 250Mbps Logic Signal to LVDS Converter Eye Diagram Test Setup. relaTeD parTs PART NUMBER
LTC6754
Typical applicaTion 15 Bit PRBS 250Mbps Logic Signal to LVDS Converter Eye Diagram Test Setup
3.3V 1GHz 3.3V BY 4 SAMPLING OSCILLOSCOPE 40mA 1k 200Ω VCCI TRGR V DIFFERENTIAL CCO +IN 6in COAX OUTPUT 16.7Ω + Q 200 mV/DIV FPGA CH1 FUNCTION = 250Mbps LTC2000 L L TC6754 TC6754 100Ω CH1 – CH2 15bit PRBS –IN 16.7Ω – CH2 Q 6in COAX 6754 TA02a VEE 200Ω 40mA 1k 2ns/DIV 6754 TA02b 3.3V
relaTeD parTs PART NUMBER DESCRIPTION COMMENTS High Speed Comparators
LTC6752/LTC6752-1/ 2.9ns 280MHz CMOS Output Comparators RR Inputs. Can drive 1.8V logic directly LTC6752-2/LTC6752-3/ (LTC6752-2/LTC6752-3/LTC6752-4) LTC6752-4 LT1715 4ns 150MHz Dual Comparators 4.6mA at 3V LT1720/LT1721 Dual/Quad 4.5ns Single Supply Comparators 4mA/Comparator LT1711 High Speed Rail-to-Rail Comparators 3V/5V/±5V, 4.5ns at 20mV Overdrive LT1116 12ns Single Supply Ground Sensing Comparator Inputs Can Exceed Positive Supply Up to 15V Without Damaging Device
Clock Buffers/Logic Converters
LTC6957-1/LTC6957-2/ Low Phase Noise, Dual Output LVPECL/LVDS/CMOS Outputs, Additive Jitter 45 fsRMS LTC6957-3/LTC6957-4 Buffer/Driver/Logic Converter
High Speed Operational Amplifiers
LTC6252/LTC6253/ Single/Dual/Quad 3.5mA 720 MHz 280V/μs, 2.75nV/√Hz, Rail-to-Rail I/O LTC6254 LTC6268/LTC6269 Single/Dual 500MHz Ultra Low Bias Current RR Outputs LTC6268-10/LTC6269-10 Single/Dual 4GHz Ultra Low Bias Current RR Outputs, Gain of 10 Stable LTC6246/LTC6247/ Single/Dual/Quad 1mA, 180MHz 90V/μs, 4.2nV/√Hz,Rail-to-Rail I/O LTC6248 6754f 22 LT 0815 • PRINTED IN USA Linear Technology Corporation 1630 McCarthy Blvd., Milpitas, CA 95Fo 0 r3 m 5- o7re 4 in 17formation www.linear.com/LTC6754 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com/LTC6754 LINEAR TECHNOLOGY CORPORATION 2015 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Package Description Revision History Typical Application Related Parts
