Datasheet LT1510, LT1510-5 (Analog Devices) - 15
Description | Constant-Voltage/Constant-Current Battery Charger |
Pages / Page | 16 / 15 — APPLICATIONS INFORMATION. Figure 13. Critical Electrical and Thermal Path … |
File Format / Size | PDF / 297 Kb |
APPLICATIONS INFORMATION. Figure 13. Critical Electrical and Thermal Path Layer
LT1510/LT1510-5
U U W U APPLICATIONS INFORMATION
GND LT1510 D1 GND GND CIN SW VCC2 BOOST VCC1 GND PROG OVP VC L1 SENSE BAT GND GND GND GND 1510 F11
Figure 13. Critical Electrical and Thermal Path Layer U PACKAGE DESCRIPTION Dimensions in inches (millimeters) unless otherwise noted. GN Package
0.189 – 0.196*
16-Lead Plastic SSOP (Narrow 0.150)
(4.801 – 4.978) 16 15 14 12 11 10 9 (LTC DWG # 05-08-1641) 13 0.015 ± 0.004 × 45° 0.053 – 0.069 0.004 – 0.009 (0.38 ± 0.10) 0.229 – 0.244 0.150 – 0.157** (1.351 – 1.748) (0.102 – 0.249) (5.817 – 6.198) (3.810 – 3.988) 0.0075 – 0.0098 0° – 8° TYP (0.191 – 0.249) 0.016 – 0.050 0.008 – 0.012 0.025 (0.406 – 1.270) (0.203 – 0.305) (0.635) BSC 1 2 3 4 5 6 7 8 * DIMENSION DOES NOT INCLUDE MOLD FLASH. MOLD FLASH SHALL NOT EXCEED 0.006" (0.152mm) PER SIDE GN16 (SSOP) 0895 ** DIMENSION DOES NOT INCLUDE INTERLEAD FLASH. INTERLEAD FLASH SHALL NOT EXCEED 0.010" (0.254mm) PER SIDE
N Package 16-Lead PDIP (Narrow 0.300)
(LTC DWG # 05-08-1510) 0.770* (19.558) 0.300 – 0.325 0.130 ± 0.005 0.045 – 0.065 MAX (7.620 – 8.255) (3.302 ± 0.127) (1.143 – 1.651) 16 15 14 13 12 11 10 9 0.015 (0.381) MIN 0.255 0.065 ± 0.015* 0.009 – 0.015 (6.477 (1.651) ± 0.381) (0.229 – 0.381) TYP +0.025 0.325 0.005 –0.015 0.125 0.018 ± 0.003 1 2 3 4 5 6 7 8 (0.127) +0.635 (3.175) 8.255 (0.457 ± 0.076) ( ) –0.381 MIN MIN 0.100 ± 0.010 *THESE DIMENSIONS DO NOT INCLUDE MOLD FLASH OR PROTRUSIONS. (2.540 ± 0.254) MOLD FLASH OR PROTRUSIONS SHALL NOT EXCEED 0.010 INCH (0.254mm) N16 0695
S8 Package
0.189 – 0.197*
8-Lead Plastic Small Outline (Narrow 0.150)
(4.801 – 5.004) (LTC DWG # 05-08-1610) 8 7 6 5 0.228 – 0.244 0.010 – 0.020 × 45° 0.053 – 0.069 (5.791 – 6.197) (0.254 – 0.508) (1.346 – 1.752) 0.004 – 0.010 0.150 – 0.157** 0.008 – 0.010 (0.101 – 0.254) (3.810 – 3.988) 0 (0.203 – 0.254) °– 8° TYP 0.016 – 0.050 0.014 – 0.019 0.050 0.406 – 1.270 (0.355 – 0.483) (1.270) BSC 1 2 3 4 *DIMENSION DOES NOT INCLUDE MOLD FLASH. MOLD FLASH SHALL NOT EXCEED 0.006" (0.152mm) PER SIDE SO8 0695 **DIMENSION DOES NOT INCLUDE INTERLEAD FLASH. INTERLEAD FLASH SHALL NOT EXCEED 0.010" (0.254mm) PER SIDE Information furnished by Linear Technology Corporation is believed to be accurate and reliable. However, no responsibility is assumed for its use. Linear Technology Corporation makes no represen- tation that the interconnection of its circuits as described herein will not infringe on existing patent rights. 15
