Datasheet LT1363 (Analog Devices) - 12
Description70MHz, 1000V/µs Op Amp
Pages / Page12 / 12 — TYPICAL APPLICATIONS. Two Op Amp Instrumentation Amplifier. 2MHz, 4th …
File Format / SizePDF / 220 Kb
TYPICAL APPLICATIONS. Two Op Amp Instrumentation Amplifier. 2MHz, 4th Order Butterworth Filter
TYPICAL APPLICATIONS Two Op Amp Instrumentation Amplifier 2MHz, 4th Order Butterworth Filter
LT1363
U TYPICAL APPLICATIONS Two Op Amp Instrumentation Amplifier 2MHz, 4th Order Butterworth Filter
R5 R4 464 220 10k Ω 549Ω Ω R1 R2 47pF 10k 1k 22pF 464Ω 1.33k R3 VIN – – 549Ω 1.13k 1k 220pF LT1363 LT1363 – – + 470pF LT1363 V – + LT1363 V OUT OUT V + IN + + 1363 TA04    4  1 2 3 ( 2 3) R     R R  R + R GAIN =   1+    +  +  = 102 R3  2 R1 R4 R       5    TRIM R5 FOR GAIN TRIM R1 FOR COMMON-MODE REJECTION 1363 TA03 BW = 700kHz
U PACKAGE DESCRIPTION Dimension in inches (millimeters) unless otherwise noted. S8 Package 8-Lead Plastic Small Outline (Narrow 0.150)
(LTC DWG # 05-08-1610) 0.189 – 0.197* (4.801 – 5.004) 0.010 – 0.020 × 45° 0.053 – 0.069 8 7 6 5 (0.254 – 0.508) (1.346 – 1.752) 0.004 – 0.010 0.008 – 0.010 0 (0.101 – 0.254) (0.203 – 0.254) °– 8° TYP 0.228 – 0.244 0.150 – 0.157** 0.016 – 0.050 (5.791 – 6.197) (3.810 – 3.988) 0.014 – 0.019 0.050 (0.406 – 1.270) (0.355 – 0.483) (1.270) TYP BSC *DIMENSION DOES NOT INCLUDE MOLD FLASH. MOLD FLASH SHALL NOT EXCEED 0.006" (0.152mm) PER SIDE **DIMENSION DOES NOT INCLUDE INTERLEAD FLASH. INTERLEAD 1 2 3 4 FLASH SHALL NOT EXCEED 0.010" (0.254mm) PER SIDE SO8 1298
RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LT1364/LT1365 Dual and Quad 70MHz, 1000V/µs Op Amps Dual and Quad Versions of LT1363 LT1360 50MHz, 800V/µs Op Amp Lower Power Version of LT1363, VOS = 1mV, IS = 4mA LT1357 25MHz, 600V/µs Op Amp Lower Power Version of LT1363, VOS = 0.6mV, IS = 2mA LT1812 100MHz, 750V/µs Op Amp Low Voltage, Low Power LT1363, VOS = 1.5mV, IS = 3mA 1363fa LT/TP 0400 2K REV A • PRINTED IN USA 12 Linear Technology Corporation 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear-tech.com LINEAR TECHNOLOGY CORPORATION 1994
