Preliminary Datasheet MM9200 (Menlo Micro) - 3
| Manufacturer | Menlo Micro |
| Description | SPST Power Switch |
| Pages / Page | 14 / 3 — v1.0. Table 2. Parameter. Symbol. Min. Max. Unit. Conditions. Gate Bias. … |
| File Format / Size | PDF / 768 Kb |
v1.0. Table 2. Parameter. Symbol. Min. Max. Unit. Conditions. Gate Bias. Voltage. Standoff. Table 3. Typ. Test Conditions. On-State Contact
link to page 5 link to page 5 link to page 5 3 MM9200 - SPST Power Switch - Preliminary Datasheet | Nov. 30, 2022
v1.0 Table 2
Recommended Operating Conditions
Parameter Symbol Min Max Unit Conditions Gate Bias
Gate bias is referenced to
Voltage
MIDPOINT, See application. Both V 88 92 V GATE negative and positive gate bias will -92 -88 turn On the device.
Voltage
V Requires MIDPOINT pin biased to STANDOFF
Standoff
the average voltage between the -300 +300 VDC INPUT and the OUTPUT pins. The absolute maximum value of VINPUT minus VOUTPUT cannot exceed 300 VDC.
Table 3
DC and AC Electrical Specifications All specifications valid over full VGATE range and full operating temperature range unless otherwise noted.
Parameter Symbol Min Typ Max Unit Test Conditions On-State Contact
ROn 10 mΩ Measured from INPUT
Resistance
to OUTPUT pins.
Off-State Contact
Measured from INPUT
Isolation
to OUTPUT pins. ROFF 5 GΩ Measured at 150 V.
Off-State Contact
100 nA Measured from INPUT
Leakage Current
to OUTPUT pins. Measured at 150 V. In addition to the MEMS path, there is a bias network which dominates the total leakage. The bias network can be adjusted to meet user requirements. Measured at 150 V.
Continuous
-10 10 A
Current
(AC/DC)
Gate Bias Current
1 nA
Capacitance
See Figure 1 and Figure 2 for equivalent circuit. Off-State, INPUT to CIO 0.55 pF OUTPUT pin © 2022 Menlo Microsystems, Inc. | All Rights Reserved | www.menlomicro.com
