Datasheet TMUX1204 (Texas Instruments)
ManufacturerTexas Instruments
Description5-V, 4:1, 1-channel, general-purpose analog multiplexer
Pages / Page35 / 1 — TMUX1204. TMUX1204 5-V, 4:1, General Purpose Analog Multiplexer. 1 …
TMUX1204. TMUX1204 5-V, 4:1, General Purpose Analog Multiplexer. 1 Features. 3 Description. 2 Applications. Device Information(1)
Datasheet TMUX1204 Texas Instruments
link to page 19 link to page 19 link to page 19 link to page 19 link to page 19 link to page 19 link to page 1 Product Order Technical Tools & Support & Folder Now Documents Software Community
TMUX1204
SCDS393A – APRIL 2019 – REVISED OCTOBER 2019
TMUX1204 5-V, 4:1, General Purpose Analog Multiplexer 1 Features 3 Description
• Rail to rail operation The TMUX1204 is a modern complementary metal- 1 oxide semiconductor (CMOS) analog multiplexer • Bidirectional signal path (MUX) in a 4:1 single-ended (1-channel) • 1.8 V Logic compatible configuration. The TMUX1204 works with a single • Fail-safe logic supply (1.08 V to 5.5 V) which allows for use in a broad array of applications from personal electronics • Low on-resistance: 5 Ω to building automation systems. A low supply current • Wide supply range: 1.08 V to 5.5 V of 10 nA enables use in portable applications. • -40°C to +125°C Operating temperature All logic inputs have 1.8 V logic compatible • Low supply current: 10 nA thresholds, ensuring both TTL and CMOS logic • Transition time: 14 ns compatibility when operating in the valid supply • Break-before-make switching voltage range. Fail-Safe Logic circuitry allows voltages on the control pins to be applied before the • ESD protection HBM: 2000 V supply pin, protecting the device from potential damage.
2 Applications
• Analog and digital multiplexing or demultiplexing
• Motor drives
PART NUMBER PACKAGE BODY SIZE (NOM)
VSSOP (10) (DGS) 3.00 mm × 3.00 mm • Servo drive control module TMUX1204 USON (10) (DQA) 2.50 mm x 1.00 mm • Building automation • Barcode scanner (1) For all available packages, see the package option addendum at the end of the data sheet. • Analog input module SPACER • Power delivery SPACER • Smoke detectors • Video surveillance • Thermal imaging camera • Electronic point of sale • Appliances • Consumer audio
Application Example TMUX1204 Block Diagram
VDD V V DD DD VI/O
TMUX120 4
EN S1
MCU LDO #1
S1
RAM FLASH
S2 D1 S2
LDO #2
S3 D
Int egrated 12-bit ADC LM20
S3
Analog Temp.
S4
Sensor
S4
Port I/O TIMERS
1-of-4
LM20 Analog Temp.
Decoder A1
Sensor
A0 GND 1.8V Logic I/O
System Inputs
EN A1 A0
and Sensors
1 An IMPORTANT NOTICE at the end of this data sheet addresses availability, warranty, changes, use in safety-critical applications, intellectual property matters and other important disclaimers. PRODUCTION DATA. Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics (VDD = 5 V ±10 %) 6.6 Electrical Characteristics (VDD = 3.3 V ±10 %) 6.7 Electrical Characteristics (VDD = 1.8 V ±10 %) 6.8 Electrical Characteristics (VDD = 1.2 V ±10 %) 6.9 Typical Characteristics 7 Parameter Measurement Information 7.1 On-Resistance 7.2 Off-Leakage Current 7.3 On-Leakage Current 7.4 Transition Time 7.5 Break-Before-Make 7.6 tON(EN) and tOFF(EN) 7.7 Charge Injection 7.8 Off Isolation 7.9 Crosstalk 7.10 Bandwidth 8 Detailed Description 8.1 Functional Block Diagram 8.2 Feature Description 8.2.1 Bidirectional Operation 8.2.2 Rail to Rail Operation 8.2.3 1.8 V Logic Compatible Inputs 8.2.4 Fail-Safe Logic 8.3 Device Functional Modes 8.4 Truth Tables 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.3 Design Requirements 9.4 Detailed Design Procedure 9.5 Application Curve 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.1.1 Layout Information 11.2 Layout Example 12 Device and Documentation Support 12.1 Documentation Support 12.1.1 Related Documentation 12.2 Receiving Notification of Documentation Updates 12.3 Community Resources 12.4 Trademarks 12.5 Electrostatic Discharge Caution 12.6 Glossary 13 Mechanical, Packaging, and Orderable Information
