VIA0050DD www.vishay.com Vishay Semiconductors High Thermal Stability Isolation AmplifierDESCRIPTION The VIA0050DD is a high performance differential output isolated amplifier ideally suited for shunt based current sensing. The device is based on proprietary capacitive isolation technology and has a linear differential input signal range of ± 50 mV (± 64 mV full scale). The device has a fixed gain of 41 and provides a differential analog output. The low offset drift typ. 0.15 μV/°C and low gain drift typ. 15 ppm/°C ensures a good accuracy over the entire temperature range. The devices unmatched CMTI of 100 kV/μs allows accurate measurements in the noisy environment. FEATURES • Isolation test voltage: 5000 VRMS VDD1 1 8 VDD2 • ± 50 mV linear input voltage range INP 2 7 OUTP • Fixed gain: 41 • gain error and drift: ± 0.05 % typ., ± 15 ppm/°C INN 3 6 OUTN typ. GND1 4 5 GND2 • Low non-linearity and drift: ± 0.03 % max., ± 1 ppm/°C typ. • SNR: 72 dB (typ., BW = 100 kHz) • Wide bandwidth: 250 kHz LINKS TO ADDITIONAL RESOURCES • High CMTI: 100 kV/μs min. D 33 • Inbuilt common-mode overvoltage detection DProduct PageApplication3D ModelsModelsEDA / CADNotes • Operating temperature: -40 °C to + 125°C • Material categorization: for definitions of compliance please see www.vishay.com/doc?99912 Design ToolsInfographicsAPPLICATIONSAGENCY APPROVALS • Isolated current measurement in: • UL - Motor control applications • cUL - Power supplies • DIN EN 60747-5-5 (VDE 0884-5) - Solar and wind energy storage systems • CQC - Charging stations and EV powertrain - Inverter and converters • Battery management DEVICE INFORMATION PART NUMBERPACKAGEBODY SIZE • 48 V board net VIA0050DD SOP-8 (300 mil) 5.85 mm x 7.50 mm Note • For automotive qualification please contact our local sales. ORDERING INFORMATIONISOLATIONLINEAR INPUTMOISTUREPART NUMBERRATINGRANGESENSITIVITYTEMPERATURE(kV)(mV)LEVEL(°C)AUTOMOTIVEPACKAGETYPESPQ VIA0050DD 5 -50 to +50 Level 3 -40 to +125 No SOP-8 (300 mil) 1000 Rev. 1.2, 02-Apr-2025 1 Document Number: 80900 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
