Datasheet VIA0050DD (Vishay) - 3
ManufacturerVishay
DescriptionHigh Thermal Stability Isolation Amplifier in SOP-8 (300 mil) Package
Pages / Page13 / 3 — VIA0050DD. PIN CONFIGURATION AND FUNCTIONS. PIN CONFIGURATION AND …
File Format / SizePDF / 205 Kb
VIA0050DD. PIN CONFIGURATION AND FUNCTIONS. PIN CONFIGURATION AND DESCRIPTION PIN NO. SYMBOL. FUNCTION
VIA0050DD PIN CONFIGURATION AND FUNCTIONS PIN CONFIGURATION AND DESCRIPTION PIN NO SYMBOL FUNCTION
VIA0050DD
V 1 8 V DD1 DD2 IN 2 7 OUT P P VIA0050DD top view IN 3 6 OUT N N GND 4 5 GND 1 2 Fig. 2 - VIA0050DD Package
PIN CONFIGURATION AND DESCRIPTION PIN NO. SYMBOL FUNCTION
1 VDD1 Power supply for isolator side 1 (3.0 V to 5.5 V) 2 INP Positive analog input (± 50 mV recommended for VIA0050DD) 3 INN Negative analog input 4 GND1 Ground 1, the ground reference for isolator side 1 5 GND2 Ground 2, the ground reference for isolator side 2 6 OUTN Negative output 7 OUTP Positive output 8 VDD2 Power supply for isolator side 2 (3.0 V to 5.5 V) Rev. 1.2, 02-Apr-2025
3
Document Number: 80900 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
