Datasheet VIA0250DD (Vishay)
ManufacturerVishay
DescriptionHigh Thermal Stability Isolation Amplifier in SOP-8 (300 mil) Package
Pages / Page13 / 1 — VIA0250DD. High Thermal Stability Isolation Amplifier. DESCRIPTION. …
File Format / SizePDF / 206 Kb
VIA0250DD. High Thermal Stability Isolation Amplifier. DESCRIPTION. FEATURES. LINKS TO ADDITIONAL RESOURCES. D 3. Product Page
Datasheet VIA0250DD Vishay
VIA0250DD
High Thermal Stability Isolation Amplifier DESCRIPTION
The VIA0250DD is a high performance differential output isolated amplifier ideally suited for shunt based current sensing. The device is based on proprietary capacitive isolation technology and has a linear differential input signal range of ± 250 mV. The low offset drift typ. 0.15 μV/°C and low gain drift typ. 15 ppm/°C ensures a good accuracy over the entire temperature range. The devices unmatched CMTI of 100 kV/μs allows accurate measurements in the noisy environment.
FEATURES
• Isolation test voltage: 5000 VRMS • ± 250 mV linear input voltage range • Fixed gain: 8.2 VDD1 1 8 VDD2 • gain error and drift: ± 0.05 % typ., ± 15 ppm/°C INP 2 7 OUTP typ. • Low non-linearity and drift: ± 0.03 % max., INN 3 6 OUTN ± 1 ppm/°C typ. GND1 4 5 GND2 • SNR: 72 dB (typ., BW = 100 kHz) • Wide bandwidth: 250 kHz • High CMTI: 150 kV/μs typ. • Inbuilt common-mode overvoltage detection
• Operating temperature: -40 °C to + 125°C
D 3 3
• Material categorization: for definitions of compliance
D Product Page Application 3D Models Models EDA / CAD
please see www.vishay.com/doc?99912
Notes Design Tools Infographics APPLICATIONS
• Isolated current measurement in: - Motor control applications
AGENCY APPROVALS
- Power supplies • UL - Charging stations • cUL - EV powertrain • DIN EN 60747-5-5 (VDE 0884-5) • Battery management • CQC • 48 V board net
Note DEVICE INFORMATION
• For automotive qualification please contact our local sales.
PART NUMBER PACKAGE BODY SIZE
VIA0250DD SOP-8 (300 mil) 5.85 mm x 7.50 mm
ORDERING INFORMATION ISOLATION LINEAR INPUT MOISTURE PART NUMBER RATING RANGE SENSITIVITY TEMPERATURE (kV) (mV) LEVEL (°C) AUTOMOTIVE PACKAGE TYPE SPQ
VIA0250DD 5 -250 to +250 Level 3 -40 to +125 No SOP-8 (300 mil) 1000 Rev. 1.2, 02-Apr-2025
1
Document Number: 80901 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
