Datasheet VIA0250DD (Vishay) - 2
ManufacturerVishay
DescriptionHigh Thermal Stability Isolation Amplifier in SOP-8 (300 mil) Package
Pages / Page13 / 2 — VIA0250DD. ABSOLUTE MAXIMUM RATINGS. PARAMETER. SYMBOL. VALUE. UNIT. …
File Format / SizePDF / 206 Kb
VIA0250DD. ABSOLUTE MAXIMUM RATINGS. PARAMETER. SYMBOL. VALUE. UNIT. Notes. FUNCTIONAL BLOCK DIAGRAM. RECOMMENDED OPERATING CONDITIONS
VIA0250DD ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL VALUE UNIT Notes FUNCTIONAL BLOCK DIAGRAM RECOMMENDED OPERATING CONDITIONS
VIA0250DD
(Tamb = 25 °C, unless otherwise specified)
Power supply voltage VDD1, VDD2 -0.3 to 6.5 V Input voltage INP, INN GND1-6 to VDD1+0.5 V Output voltage OUTP, OUTN GND2-0.5 to VDD2+0.5 V Output current per output pin IO -10 to +10 mA Operating temperature Tamb -40 to +125 °C Junction temperature Tj -40 to +150 °C Storage temperature Tstg -55 to +150 °C HBM (1) ± 2000 V Electrostatic discharge CDM (2) ± 1000 V
Notes
(1) Human body model (HBM), per AEC-Q100-002-RevD (2) Charged device model (CDM), per AEC-Q100-011-RevB
V V DD1 DD2 V detection DD1 Reference Reference INP Retiming and 4th - OUTP Σ-Δ modulator TX RX order active low pass OUTN filter INN Isolation Barrier RX TX Oscillator V detection CM GND GND 1 2 Fig. 1 - VIA0250DD Block Diagram
PARAMETER SYMBOL MIN. TYP. MAX. UNIT
Side 1 power supply VDD1 3.0 5.0 5.5 V Side 2 power supply VDD2 3.0 3.3 5.5 V Differential input voltage V 320 - mV before clipping output clipping - ± Linear differential input full VIA0250DD V scale voltage FSR -250 - +250 mV Operating common-mode V input voltage CM -0.16 - +0.8 V Operating ambient temperature Tamb -40 - +125 °C Rev. 1.2, 02-Apr-2025
2
Document Number: 80901 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
