Datasheet RA2L2 (Renesas) - 4
ManufacturerRenesas
DescriptionUltra low power 48 MHz Arm® Cortex®-M23 core, up to 128-KB code flash memory, 16-KB SRAM, USB 2.0 Full-Speed module (USBFS), USB Type-C® interface (USBCC), 12-bit A/D Converter, Security and Safety features.
Pages / Page108 / 4 — Table 1.6. Timers (2 of 2). Feature. Functional description. Table 1.7. …
Table 1.6. Timers (2 of 2). Feature. Functional description. Table 1.7. Communication interfaces
Table 1.6 Timers (2 of 2) Feature Functional description Table 1.7 Communication interfaces
RA2L2 Datasheet 1. Overview
Low power Asynchronous General The Low Power Asynchronous General Purpose Timer (AGTW) is a 32-bit timer that can be Purpose Timer (AGTW) used for pulse output, external pulse width or period measurement, and counting external events. This timer consists of a reload register and a down counter. The reload register and the down counter are allocated to the same address, and can be accessed with the AGTW register. Realtime Clock (RTC) The RTC has two operation modes, normal operation mode and low-consumption clock mode. In each of the operation mode, the RTC has two counting modes, calendar count mode and binary count mode, that are used by switching register settings. For calendar count mode, the RTC has a 100-year calendar from 2000 to 2099 and automatically adjusts dates for leap years. For binary count mode, the RTC counts seconds and retains the information as a serial value. Binary count mode can be used for calendars other than the Gregorian (Western) calendar.
Table 1.7 Communication interfaces Feature Functional description
Serial Communications Interface (SCI) The Serial Communications Interface (SCI) × 4 channels have asynchronous and synchronous serial interfaces: ● Asynchronous interfaces (UART and Asynchronous Communications Interface Adapter (ACIA)) ● 8-bit clock synchronous interface ● Simple IIC (master-only) ● Simple SPI ● Smart card interface The smart card interface complies with the ISO/IEC 7816-3 standard for electronic signals and transmission protocol. SCIn (n = 0) has FIFO buffers to enable continuous and full-duplex communication, and the data transfer speed can be configured independently using an on-chip baud rate generator. I3C bus interface (I3C) The I3C bus interface (I3C) has one channel. The I3C module conform with and provide a subset of the NXP I2C (Inter-Integrated Circuit) bus interface functions and a subset of the MIPI I3C. Serial Peripheral Interface (SPI) The Serial Peripheral Interface (SPI) has 1 channel. The SPI provides high-speed full-duplex synchronous serial communications with multiple processors and peripheral devices. Control Area Network (CAN) The Controller Area Network (CAN) module uses a message-based protocol to receive and transmit data between multiple slaves and masters in electromagnetically noisy applications. The module complies with the ISO 11898-1 (CAN 2.0A/CAN 2.0B) standard and supports up to 32 mailboxes, which can be configured for transmission or reception in normal mailbox and FIFO modes. Both standard (11-bit) and extended (29-bit) messaging formats are supported. The CAN module requires an additional external CAN transceiver. USB 2.0 Full-Speed module (USBFS) The USB 2.0 Full-Speed module (USBFS) can operate as a device controller. The module supports full-speed transfer as defined in Universal Serial Bus Specification 2.0. The module has an internal USB transceiver and supports all of the transfer types defined in Universal Serial Bus Specification 2.0. The USB has buffer memory for data transfer, providing a maximum of 10 pipes. Pipes 1 to 9 can be assigned any endpoint number based on the peripheral devices used for communication or based on your system. USB Type-C interface (USBCC) The module supports for USB Type-C connector of USB 2.0 (Sink/UFP only) as defined in Universal Serial Bus Type-C Cable and Connector Specification Release 2.2, and the module can detect the current supply capability (default /1.5A/3.0A) of VBUS. Serial interface UARTA (UARTA) The serial interface UARTA (UARTA) has 2 channels. The UARTA provides full-duplex asynchronous serial communications. Serial Sound Interface Enhanced (SSIE) The Serial Sound Interface Enhanced (SSIE) peripheral provides functionality to interface with digital audio devices for transmitting I2S/Monaural/TDM audio data over a serial bus. The SSIE supports an audio clock frequency of up to 32 MHz, and can be operated as a slave or master receiver, transmitter, or transceiver to suit various applications. The SSIE includes 32-stage FIFO buffers in the receiver and transmitter, and supports interrupts and DTC-driven data reception and transmission. R01DS0445EJ0110 Rev.1.10 Page 4 of 108 Mar 12, 2025 Document Outline Features 1. Overview 1.1 Function Outline 1.2 Block Diagram 1.3 Part Numbering 1.4 Function Comparison 1.5 Pin Functions 1.6 Pin Assignments 1.7 Pin Lists 2. Electrical Characteristics 2.1 Absolute Maximum Ratings 2.2 DC Characteristics 2.2.1 Tj/Ta Definition 2.2.2 I/O VIH, VIL 2.2.3 I/O IOH, IOL 2.2.4 I/O VOH, VOL, and Other Characteristics 2.2.5 Operating and Standby Current 2.2.6 VCC Rise and Fall Gradient and Ripple Frequency 2.2.7 Thermal Characteristics 2.3 AC Characteristics 2.3.1 Frequency 2.3.2 Clock Timing 2.3.3 Reset Timing 2.3.4 Wakeup Time 2.3.5 NMI and IRQ Noise Filter 2.3.6 I/O Ports, POEG, GPT, AGTW, KINT, and ADC12 Trigger Timing 2.3.7 CAC Timing 2.3.8 SCI Timing 2.3.9 SPI Timing 2.3.10 I3C Timing 2.3.11 SSIE Timing 2.3.12 UARTA Timing 2.3.13 CLKOUT Timing 2.4 USB Characteristics 2.4.1 USBFS Timing 2.4.2 USBCC Characteristics 2.5 ADC12 Characteristics 2.6 TSN Characteristics 2.7 OSC Stop Detect Characteristics 2.8 POR and LVD Characteristics 2.9 Flash Memory Characteristics 2.9.1 Code Flash Memory Characteristics 2.9.2 Data Flash Memory Characteristics 2.10 Serial Wire Debug (SWD) Appendix 1. Port States in each Processing Mode Appendix 2. Package Dimensions Appendix 3. I/O Registers 3.1 Peripheral Base Addresses 3.2 Access Cycles Revision History General Precautions Notice
