Datasheet MMSZ52 (ON Semiconductor) - 3
| Manufacturer | ON Semiconductor |
| Description | Zener Diode 500 mW SOD-123 |
| Pages / Page | 8 / 3 — MMSZ52xxxT1G Series, SZMMSZ52xxxT1G Series. 5% TOLERANCE FG ELECTRICAL … |
| File Format / Size | PDF / 221 Kb |
MMSZ52xxxT1G Series, SZMMSZ52xxxT1G Series. 5% TOLERANCE FG ELECTRICAL CHARACTERISTICS. Leakage Cur-. Zener Voltage
link to page 3 link to page 3 link to page 3
MMSZ52xxxT1G Series, SZMMSZ52xxxT1G Series 5% TOLERANCE FG ELECTRICAL CHARACTERISTICS
(TA = 25°C unless otherwise noted, VF = 0.9 V Max. @ IF = 10 mA)
Leakage Cur- Zener Voltage
(Notes 3 and 4)
Zener Impedance
(Note 5)
rent Device VZ (Volts) @ IZT ZZT @ IZT ZZK @ IZK IR @ VR Device* Marking Min Nom Max mA W W mA mA Volts
MMSZ5221BT1G C1 2.28 2.4 2.52 20 30 1200 0.25 100 1 MMSZ5222BT1G C2 2.38 2.5 2.63 20 30 1250 0.25 100 1 MMSZ5223BT1G C3 2.57 2.7 2.84 20 30 1300 0.25 75 1 MMSZ5224BT1G C4 2.66 2.8 2.94 20 30 1400 0.25 75 1 MMSZ5225BT1G C5 2.85 3.0 3.15 20 29 1600 0.25 50 1 MMSZ5226BT1G D1 3.14 3.3 3.47 20 28 1600 0.25 25 1 MMSZ5227BT1G D2 3.42 3.6 3.78 20 24 1700 0.25 15 1 MMSZ5228BT1G D3 3.71 3.9 4.10 20 23 1900 0.25 10 1 MMSZ5229BT1G D4 4.09 4.3 4.52 20 22 2000 0.25 5 1 MMSZ5230BT1G D5 4.47 4.7 4.94 20 19 1900 0.25 5 2 MMSZ5231BT1G E1 4.85 5.1 5.36 20 17 1600 0.25 5 2 MMSZ5232BT1G E2 5.32 5.6 5.88 20 11 1600 0.25 5 3 MMSZ5233BT1G E3 5.70 6.0 6.30 20 7 1600 0.25 5 3.5 MMSZ5234BT1G E4 5.89 6.2 6.51 20 7 1000 0.25 5 4 MMSZ5235BT1G E5 6.46 6.8 7.14 20 5 750 0.25 3 5 MMSZ5236BT1G F1 7.13 7.5 7.88 20 6 500 0.25 3 6 MMSZ5237BT1G F2 7.79 8.2 8.61 20 8 500 0.25 3 6.5 MMSZ5238BT1G F3 8.27 8.7 9.14 20 8 600 0.25 3 6.5 MMSZ5239BT1G F4 8.65 9.1 9.56 20 10 600 0.25 3 7 MMSZ5240BT1G F5 9.50 10 10.50 20 17 600 0.25 3 8 MMSZ5241BT1G H1 10.45 11 11.55 20 22 600 0.25 2 8.4 MMSZ5242BT1G/T3G H2 11.40 12 12.60 20 30 600 0.25 1 9.1 MMSZ5243BT1G H3 12.35 13 13.65 9.5 13 600 0.25 0.5 9.9 MMSZ5244BT1G H4 13.30 14 14.70 9.0 15 600 0.25 0.1 10 MMSZ5245BT1G H5 14.25 15 15.75 8.5 16 600 0.25 0.1 11 MMSZ5246BT1G J1 15.20 16 16.80 7.8 17 600 0.25 0.1 12 MMSZ5247BT1G J2 16.15 17 17.85 7.4 19 600 0.25 0.1 13 MMSZ5248BT1G J3 17.10 18 18.90 7.0 21 600 0.25 0.1 14 MMSZ5249BT1G J4 18.05 19 19.95 6.6 23 600 0.25 0.1 14 MMSZ5250BT1G J5 19.00 20 21.00 6.2 25 600 0.25 0.1 15 MMSZ5251BT1G K1 20.90 22 23.10 5.6 29 600 0.25 0.1 17 MMSZ5252BT1G K2 22.80 24 25.20 5.2 33 600 0.25 0.1 18 MMSZ5253BT1G K3 23.75 25 26.25 5.0 35 600 0.25 0.1 19 MMSZ5254BT1G/T3G K4 25.65 27 28.35 4.6 41 600 0.25 0.1 21 MMSZ5255BT1G K5 26.60 28 29.40 4.5 44 600 0.25 0.1 21 MMSZ5256BT1G M1 28.50 30 31.50 4.2 49 600 0.25 0.1 23 MMSZ5257BT1G M2 31.35 33 34.65 3.8 58 700 0.25 0.1 25 MMSZ5258BT1G/T3G M3 34.20 36 37.80 3.4 70 700 0.25 0.1 27 MMSZ5259BT1G M4 37.05 39 40.95 3.2 80 800 0.25 0.1 30 MMSZ5260BT1G M5 40.85 43 45.15 3.0 93 900 0.25 0.1 33 MMSZ5261BT1G N1 44.65 47 49.35 2.7 105 1000 0.25 0.1 36 MMSZ5262BT1G N2 48.45 51 53.55 2.5 125 1100 0.25 0.1 39 MMSZ5263BT1G N3 53.20 56 58.80 2.2 150 1300 0.25 0.1 43 MMSZ5264BT1G N4 57.00 60 63.00 2.1 170 1400 0.25 0.1 46 MMSZ5265BT1G N5 58.90 62 65.10 2.0 185 1400 0.25 0.1 47 MMSZ5266BT1G P1 64.60 68 71.40 1.8 230 1600 0.25 0.1 52 MMSZ5267BT1G P2 71.25 75 78.75 1.7 270 1700 0.25 0.1 56 MMSZ5268BT1G P3 77.90 82 86.10 1.5 330 2000 0.25 0.1 62 MMSZ5269BT1G P4 82.65 87 91.35 1.4 370 2200 0.25 0.1 68 MMSZ5270BT1G P5 86.45 91 95.55 1.4 400 2300 0.25 0.1 69 MMSZ5272BT1G/T3G R2 104.5 110 115.5 1.1 750 3000 0.25 0.1 84 *Includes SZ-prefix devices where applicable. 3. “B” Suffix Type numbers shown have a standard tolerance of ±5% on the nominal Zener voltages. 4. Nominal Zener voltage is measured with the device junction in thermal equilibrium at TL = 30°C ±1°C. 5. ZZT and ZZK are measured by dividing the AC voltage drop across the device by the ac current applied. The specified limits are for IZ(AC) = 0.1 IZ(dc) with the AC frequency = 1 kHz.
www.onsemi.com 3
