Datasheet HC-05 (Silicon Microstructures) - 7
| Manufacturer | Silicon Microstructures |
| Description | Bluetooth to Serial Port Module |
| Pages / Page | 13 / 7 — Tech Support: info@iteadstudio.com |
| File Format / Size | PDF / 861 Kb |
OK 1-Master 2-Slave-Loop 9. Set/Check device class Command Respond Parameter AT+CLASS=<Param> OK Param: Device Class AT+ CLASS? 1. +CLASS:<Param> OK 2. FAIL 10. Set/Check GIAC (General Inquire Access Code) Command Respond Parameter AT+IAC=<Param> 1.OK Param: GIAC 2. FAIL (Default : 9e8b33) AT+IAC +IAC:<Param> OK Example: AT+IAC=9e8b3f\r\n OK AT+IAC?\r\n +IAC: 9e8b3f OK 11. Set/Check -- Query access patterns Command Respond Parameter AT+INQM=<Param>,<Param2>, 1.OK Param: <Param3> 2. FAIL 0——inquiry_mode_standard AT+ INQM? +INQM : <Param>,<Param2>, 1——inquiry_mode_rssi <Param3> Param2: Maximum number of OK Bluetooth devices to respond to Param3: Timeout (1-48 : 1.28s to 61.44s) Example: AT+INQM=1,9,48\r\n OK AT+INQM\r\n +INQM:1, 9, 48 OK HC-05 Bluetooth module iteadstudio.com 06.18.2010
