Datasheet SB520A, SB530A, SB540A, SB550A, SB560A (Vishay)
ManufacturerVishay
DescriptionSchottky Barrier Rectifier in DO-201AD package
Pages / Page4 / 1 — SB520A, SB530A, SB540A, SB550A, SB560A. Schottky Barrier Plastic …
File Format / SizePDF / 77 Kb
SB520A, SB530A, SB540A, SB550A, SB560A. Schottky Barrier Plastic Rectifier. FEATURES. DO-201AD. TYPICAL APPLICATIONS
Datasheet SB520A, SB530A, SB540A, SB550A, SB560A Vishay
www.vishay.com Vishay General Semiconductor
Schottky Barrier Plastic Rectifier FEATURES
• Guardring for overvoltage protection • Very small conduction losses • Extremely fast switching • Low forward voltage drop • High frequency operation • Solder dip 275 °C max. 10 s, per JESD 22-B106
DO-201AD
• Material categorization: For definitions of compliance please see www.vishay.com/doc?99912
For use in low voltage high frequency inverters, freewheeling, DC/DC converters, and polarity protection
PRIMARY CHARACTERISTICS
applications. IF(AV) 5.0 A VRRM 20 V, 30 V, 40 V, 50 V, 60 V
MECHANICAL DATA
IFSM 150 A
Case:
DO-201AD VF 0.50 V, 0.70 V Molding compound meets UL 94 V-0 flammability rating TJ max. 150 °C Base P/N-E3 - RoHS-compliant, commercial grade Package DO-201AD
Terminals:
Matte tin plated leads, solderable per Diode variations Single J-STD-002 and JESD 22-B102 E3 suffix meets JESD 201 class 1A whisker test
Polarity:
Color band denotes the cathode end
MAXIMUM RATINGS
(TA = 25 °C unless otherwise noted)
PARAMETER SYMBOL SB520A SB530A SB540A SB550A SB560A UNIT
Maximum repetitive peak reverse voltage VRRM 20 30 40 50 60 V Maximum RMS voltage VRMS 14 21 28 35 42 V Maximum DC blocking voltage VDC 20 30 40 50 60 V Maximum average forward rectified current I at 0.375" (9.5 mm) lead length (fig. 1) F(AV) 5.0 A Peak forward surge current, 8.3 ms single half I sine-wave superimposed on rated load FSM 150 A Operating junction temperature range TJ - 65 to + 150 °C Storage temperature range TSTG - 65 to + 150 °C
ELECTRICAL CHARACTERISTICS
PARAMETER TEST CONDITIONS SYMBOL SB520A SB530A SB540A SB550A SB560A UNIT
Maximum instantaneous 5.0 A V forward voltage F (1) 0.50 0.70 V Maximum reverse current TA = 25 °C 0.5 I mA at rated V R (2) R TA = 100 °C 50 25
Notes
(1) Pulse test: 300 μs pulse width, 1 % duty cycle (2) Pulse test: Pulse width  40 ms Revision: 20-Jan-14
1
Document Number: 88903 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
