Datasheet SB520A, SB530A, SB540A, SB550A, SB560A (Vishay) - 2
ManufacturerVishay
DescriptionSchottky Barrier Rectifier in DO-201AD package
Pages / Page4 / 2 — SB520A, SB530A, SB540A, SB550A, SB560A. THERMAL CHARACTERISTICS. …
File Format / SizePDF / 77 Kb
SB520A, SB530A, SB540A, SB550A, SB560A. THERMAL CHARACTERISTICS. PARAMETER. SYMBOL. SB520A. SB530A. SB540A. SB550A. SB560A. UNIT. Note
SB520A, SB530A, SB540A, SB550A, SB560A THERMAL CHARACTERISTICS PARAMETER SYMBOL SB520A SB530A SB540A SB550A SB560A UNIT Note
www.vishay.com Vishay General Semiconductor
(TA = 25 °C unless otherwise noted)
RJA (1) 25 Typical thermal resistance RJC (1) 10 °C/W RJL (1) 8
Note
(1) Thermal resistance from junction to lead PCB mounting 0.375" (9.5 mm) lead length
ORDERING INFORMATION
(Example)
PREFERRED P/N UNIT WEIGHT (g) PREFERRED PACKAGE CODE BASE QUANTITY DELIVERY MODE
SB540A-E3/54 1.08 54 1400 13" diameter paper tape and reel SB540A-E3/73 1.08 73 1000 Ammo pack packaging
RATINGS AND CHARACTERISTICS CURVES
(TA = 25 °C unless otherwise noted) 5.0 100 T = 125 °C J 4.0 ent (A) 10 ent (A) Pulse Width = 300 μs 1 % Duty Cycle d Curr 3.0 d Curr 1 Forwar T = 25 °C J 2.0 s Resistive or Inductive Load 0.375" (9.5 mm) Lead Length 0.1 verage Forwar 1.0 A tantaneou SB520A to SB540A SB520A to SB540A s SB550A, SB560A In SB550A, SB560A 0 0.01 0 20 40 60 80 100 120 150 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 Lead Temperature (°C) Instantaneous Forward Voltage (V) Fig. 1 - Forward Current Derating Curve Fig. 3 - Typical Instantaneous Forward Characteristics 180 100 150 10 T = 125 °C J ent (A) ent (mA) 120 1 e Curr T = 75 °C ge Curr s J ur 90 S 0.1 d Rever s 60 0.01 T = 25 °C J 30 0.001 Peak Forwar tantaneou s SB520A to SB540A In SB550A, SB560A 0 0.0001 1 10 100 0 20 40 60 80 100 Number of Cycles at 60 Hz Percent of Rated Peak Reverse Voltage (%) Fig. 2 - Maximum Non-Repetitive Peak Forward Surge Current Fig. 4 - Typical Reverse Characteristics Revision: 20-Jan-14
2
Document Number: 88903 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
