Datasheet IM (TE Connectivity) - 6
ManufacturerTE Connectivity
DescriptionGeneral Purpose Signal Relay, DC, Polarized, Monostable, 2 Form C DPDT-CO, 2 A Contact Rating, 3 VDC Coil Voltage, 250 VAC Contact Voltage, Axicom IM
Pages / Page11 / 6 — IM Relay. AXICOM IM RELAY. PROCESSING. Recommended reflow soldering …
File Format / SizePDF / 3.2 Mb
IM Relay. AXICOM IM RELAY. PROCESSING. Recommended reflow soldering profile IEC 61760-1. Rec
IM Relay AXICOM IM RELAY PROCESSING Recommended reflow soldering profile IEC 61760-1 Rec
108-98001 Rev. M AXICOMÊSignalÊRelays AXICOMÊSignalÊRelays
IM Relay
108-98001 Rev. M
IM Relay
Packing Dimensions in mm Packing Dimensions in mm
AXICOM IM RELAY
SIGNAL RELAYS 108-98001 Rev. M AXICOMÊSignalÊRelays
PROCESSING IM Relay
Recommended soldering conditions
Packing
Rec ommended vapor phase soldering profile
Dimensions in mm
Recommended soldering conditions Vapour phase soldering
20 to 40s full line: typical dotted line: process limits 240°C 180°C 130°C Tube for THT version forced cooling external preheating Tube for THT version 50 relays per tube 100°C 50 relays per tube 1,000 relays per box e [°C] 1,000 relays per box
temperature/time profile (lead and housing peak temp.) Temperatur Time [s] 108-98001 Rev. M AXICOMÊSignalÊRelays Copyright © 2015 IEC Geneva, Switz
IM Rela
erland.
y
PACKING
T
Packing
ube f or THT version Tape and reel f
Dimensions in mm
or SMT version
50 relays per tube, 1000 relays per box 1000 relays per reel, 1000 or 5000 relays per box Tape and reel for SMT version 1,000 relays per reel 1,000 or 5,000 relays per box Tape and reel for SMT version 1,000 relays per reel 1,000 or 5,000 relays per box Tube for THT version Reel Dimension 50 relays per tube Tape and reel for SMT version 1,000 relays per box 1,000 relays per reel 1,000 or 5,000 relays per box
Reel dimensions
Reel Dimension Reel Dimension All specifications subject to change. Consult Tyco Electronics for latest specifications. 26 of 28 Tape and reel for SMT version 1,000 relays per reel 1,000 or 5,000 relays per box All specifications subject to change. Consult Tyco Electronics for latest specifications. 26 of 28
Note:
The author thanks the International Electrotechnical Commission (IEC) for permission to reproduce Information from its International Standards. All such extracts are copyright Reel Dimension of IEC, Geneva, Switzerland. All rights reserved. Further information on the IEC is av All specifications subject to change. Consult T ailable from www.iec.ch. IEC has no responsibility f yco Electr or the plac onics for latest specifications. ement and context in which the 26 of 28 extracts and contents are reproduced by the author, nor is IEC in any way responsible for the other content or accuracy therein.” INDUSTRIAL /
AXICOM IM RELAY
6 All specifications subject to change. Consult Tyco Electronics for latest specifications. 26 of 28 Document Outline Introduction Features Applications Approvals Contact Data Max. DC load breaking capacity Coil Data Coil versions, standard version, monostable, 1 coil Coil operating range, standard version, monostable, 1 coil Coil versions, sensitive version, monostable, 1 coil Coil versions, ultra high sensitive version, monostable, 1 coil Coil operating range, sensitive and ultra high sensitive version, monostable, 1 coil Coil versions, standard version, bistable 1 coil Coil operating range, Standard version, bistable, 1 coil Insulation Data Other Data Monostable version rest condition Bistable version, 1 coil reset condition RF data Dimensions PCB layout Processing Packing Product code structure Product Selection Information
