Datasheet 2N5060, 2N5061, 2N5062, 2N5064 (ON Semiconductor) - 2
ManufacturerON Semiconductor
DescriptionSensitive Gate Silicon Controlled Rectifiers 0.8 A RMS in TO-92 package
Pages / Page9 / 2 — 2N5060 Series. THERMAL CHARACTERISTICS. Characteristic. Symbol. Max. …
File Format / SizePDF / 208 Kb
2N5060 Series. THERMAL CHARACTERISTICS. Characteristic. Symbol. Max. Unit. ELECTRICAL CHARACTERISTICS. Min. Typ. OFF CHARACTERISTICS
2N5060 Series THERMAL CHARACTERISTICS Characteristic Symbol Max Unit ELECTRICAL CHARACTERISTICS Min Typ OFF CHARACTERISTICS
link to page 2 link to page 2 link to page 2 link to page 2 link to page 2 link to page 2
*Thermal Resistance, Junction−to−Case (Note 2) RqJC 75 °C/W Thermal Resistance, Junction−to−Ambient RqJA 200 °C/W 2. This measurement is made with the case mounted “flat side down” on a heatsink and held in position by means of a metal clamp over the curved surface. *Indicates JEDEC Registered Data.
(TC = 25°C unless otherwise noted)
Characteristic Symbol Min Typ Max Unit OFF CHARACTERISTICS
*Peak Repetitive Forward or Reverse Blocking Current (Note 3) IDRM, IRRM (VAK = Rated VDRM or VRRM) TC = 25°C − − 10 mA TC = 110°C − − 50 mA
ON CHARACTERISTICS
*Peak Forward On−State Voltage (Note 4) VTM − − 1.7 V (ITM = 1.2 A peak @ TA = 25°C) Gate Trigger Current (Continuous DC) (Note 5) IGT mA *(VAK = 7.0 Vdc, RL = 100 W) TC = 25°C − − 200 TC = −40°C − − 350 Gate Trigger Voltage (Continuous DC) (Note 5) TC = 25°C VGT − − 0.8 V *(VAK = 7.0 Vdc, RL = 100 W) TC = −40°C − − 1.2 *Gate Non−Trigger Voltage VGD V (VAK = Rated VDRM, RL = 100 W) TC = 110°C 0.1 − − Holding Current (Note 3) TC = 25°C IH − − 5.0 mA *(VAK = 7.0 Vdc, initiating current = 20 mA) TC = −40°C − − 10 Turn-On Time ms Delay Time td − 3.0 − Rise Time tr − 0.2 − (IGT = 1.0 mA, VD = Rated VDRM, Forward Current = 1.0 A, di/dt = 6.0 A/ms Turn-Off Time tq ms (Forward Current = 1.0 A pulse, Pulse Width = 50 ms, 0.1% Duty Cycle, di/dt = 6.0 A/ms, dv/dt = 20 V/ms, IGT = 1 mA) 2N5060, 2N5061 − 10 − 2N5062, 2N5064 − 30 −
DYNAMIC CHARACTERISTICS
Critical Rate of Rise of Off−State Voltage dv/dt − 30 − V/ms (Rated VDRM, Exponential, RGK = 1 kW) *Indicates JEDEC Registered Data. 3. RGK = 1000 W is included in measurement. 4. Forward current applied for 1 ms maximum duration, duty cycle p 1%. 5. RGK current is not included in measurement.
www.onsemi.com 2
