Datasheet TL431A, TL431B, NCV431A, NCV431B, SCV431A (ON Semiconductor) - 2
ManufacturerON Semiconductor
DescriptionProgrammable Precision References
Pages / Page23 / 2 — TL431A, B Series, NCV431A, B Series, SCV431A. Figure 1. Symbol. Figure 2. …
File Format / SizePDF / 686 Kb
TL431A, B Series, NCV431A, B Series, SCV431A. Figure 1. Symbol. Figure 2. Representative Block Diagram
TL431A, B Series, NCV431A, B Series, SCV431A Figure 1 Symbol Figure 2 Representative Block Diagram
link to page 2
Cathode (K) Cathode (K) Reference (R) 800 800 Anode Reference (R) 20 pF (A)
Figure 1. Symbol
Reference Cathode 150 3.28 k (R) (K) 4.0 k + 20 pF 10 k - 2.4 k 7.2 k 2.5 Vref 1.0 k Anode (A) 800
This device contains 12 active transistors. Anode (A)
Figure 3. Representative Schematic Diagram
Component values are nominal
MAXIMUM RATINGS
(Full operating ambient temperature range applies, unless otherwise noted.)
Rating Symbol Value Unit
Cathode to Anode Voltage VKA 37 V Cathode Current Range, Continuous IK −100 to +150 mA Reference Input Current Range, Continuous Iref −0.05 to +10 mA Operating Junction Temperature TJ 150 °C Operating Ambient Temperature Range TA °C TL431I, TL431AI, TL431BI −40 to +85 TL431C, TL431AC, TL431BC 0 to +70 NCV431AI, NCV431B, TL431BV, SCV431AI −40 to +125 Storage Temperature Range Tstg −65 to +150 °C Total Power Dissipation @ TA = 25 °C PD W Derate above 25 °C Ambient Temperature D, LP Suffix Plastic Package 0.70 P Suffix Plastic Package 1.10 DM Suffix Plastic Package 0.52 Total Power Dissipation @ TC = 25 °C PD W Derate above 25 °C Case Temperature D, LP Suffix Plastic Package 1.5 P Suffix Plastic Package 3.0 ESD Rating (Note 1) V Human Body Model per JEDEC JESD22-A114F HBM >2000 Machine Model per JEDEC JESD22-A115C MM >200 Charged Device Model per JEDEC JESD22-C101E CDM >500 Stresses exceeding those listed in the Maximum Ratings table may damage the device. If any of these limits are exceeded, device functionality should not be assumed, damage may occur and reliability may be affected. 1. This device contains latch-up protection and exceeds ±100 mA per JEDEC standard JESD78.
RECOMMENDED OPERATING CONDITIONS Condition Symbol Min Max Unit
Cathode to Anode Voltage VKA Vref 36 V Cathode Current IK 1.0 100 mA Functional operation above the stresses listed in the Recommended Operating Ranges is not implied. Extended exposure to stresses beyond the Recommended Operating Ranges limits may affect device reliability.
www.onsemi.com Share Feedback 2
Your Opinion Matters
