Datasheet DS1000Z-E Series (Rigol) - 7
ManufacturerRigol
DescriptionDigital Oscilloscope
Pages / Page8 / 7 — Ordering Information. Standard Software. RIGOL. Warranty
File Format / SizePDF / 796 Kb
Ordering Information Standard Software RIGOL Warranty
Regulation Standards
Compliant with EMC DIRECTIVE 2014/30/EU, compliant with or higher Description Order Number than the standards specified in IEC 61326-1:2013/EN 61326-1:2013 Group DS1202Z-E (200 1 Class A Models MHz, 2 analog DS1202Z-E channels) CISPR 11/EN 55011 IEC 61000-4- ±4.0 kV (contact Power cord 2:2008/EN 61000- discharge), ±8.0 conforming to the 4-2 kV (air discharge) standard of the - 3 V/m (80 MHz to Standard destination country IEC 61000-4- 1 GHz); 3 V/m (1.4 Accessories 3:2002/EN 61000- GHz to 2 GHz); 1 USB cable CB-USBA-USBB- FF-150 4-3 V/m (2.0 GHz to 2.7 GHz) 2 passive probes (350 MHz) PVP2350 IEC 61000-4- 4:2004/EN 61000- 1 kV power line Optional Electromagnetic 4-4 Accessory Rack mount kit RM-DS1000Z Compatibility 0.5 kV (phase-to- IEC 61000-4- neutral voltage); 1 5:2001/EN 61000- kV (phase-to-earth 4-5 voltage); 1 kV (neutral-to-earth
Standard Software
voltage) IEC 61000-4- 6:2003/EN 61000- 3 V, 0.15-80 MHz Ultra Sigma 4-6 voltage dip: 0% UT during half cycle; IEC 61000-4- 0% UT during 1 11:2004/EN 61000- cycle; 70% UT 4-11 during 25 cycles short interruption: 0% UT during 250 cycles IEC 61010-1:2010 (Third Edition)/EN Safety 61010-1:2010, UL 61010-1:2012 R4.16 and CAN/
RIGOL
general PC software platform CSA-C22.2 NO. 61010-1-12+ GI1+ GI2 Multi-instrument and multi-interface resource management Meets GB/T 6587; class 2 random With SCPI remote command tool Vibration Meets MIL-PRF-28800F and IEC60068- 2-6; class 3 random Meets GB/T 6587-2012; class 2 random Ultra Scope Meets MIL-PRF-28800F and IEC60068- Shock 2-27; class 3 random (in non-operating conditions: 30 g, half sine, 11 ms duration, 3 shocks along the main axis, a total of 18 vibrations) Note[1]: Typical. Note[2]: Maximum value. 50 ns, single-channel mode, dots display, auto memory depth. Note[3]: Supporting legs and handle folded, knob height included. Note[4]: Standard configuration. Real-time monitoring of waveform and status; supports multi-instrument and multi-window display With virtual panel feature Supports multi-interface remote control
Warranty
Three -year warranty, excluding probes and accessories. 7
