link to page 2 link to page 2 link to page 2 link to page 2 MCP6V51Figure 1 and Figure 2 show input offset voltage versus As seen in Figure 1 and Figure 2 , the MCP6V51 op ambient temperature for different power supply amps have excellent performance across temperature. voltages. The input offset voltage temperature drift (TC1) shown is well within the specified maximum values of 8 31 nV/°C at VDD = 4.5V and 36 nV/°C at VDD = 45V. 22 Samples6V= 4.5VDD This performance supports applications with stringent 4 DC precision requirements. In many cases, it will not be necessary to correct for temperature effects (i.e., 2ltage (μV) o calibrate) in a design. In the other cases, the correction 0 will be small. -2-4Input Offset V -6-8-50-250255075100125Ambient Temperature (°C)FIGURE 1: Input Offset Voltage vs. Ambient Temperature with VDD = 4.5V. 822 Samples6V= 45VDD42ltage (μV) o0-2-4Input Offset V -6-8-50-250255075100125Ambient Temperature (°C)FIGURE 2: Input Offset Voltage vs. Ambient Temperature with VDD = 45V. DS20006136A-page 2 2018 Microchip Technology Inc. Document Outline 45V, 2 MHz Zero-Drift Op Amp with EMI Filtering Features Typical Applications Design Aids Related Parts General Description Package Types Typical Application Circuit FIGURE 1: Input Offset Voltage vs. Ambient Temperature with VDD = 4.5V. FIGURE 2: Input Offset Voltage vs. Ambient Temperature with VDD = 45V. 1.0 Electrical Characteristics 1.1 Absolute Maximum Ratings 1.2 Electrical Specifications DC Electrical Specifications AC Electrical Specifications Temperature Specifications 1.3 Timing Diagrams FIGURE 1-1: Amplifier Start-Up. FIGURE 1-2: Offset Correction Settling Time. FIGURE 1-3: Output Overdrive Recovery. 1.4 Test Circuits FIGURE 1-4: AC and DC Test Circuit for Most Noninverting Gain Conditions. FIGURE 1-5: AC and DC Test Circuit for Most Inverting Gain Conditions. FIGURE 1-6: Test Circuit for Dynamic Input Behavior. 2.0 Typical Performance Curves 2.1 DC Input Precision FIGURE 2-1: Input Offset Voltage. FIGURE 2-2: Input Offset Voltage Drift. FIGURE 2-3: Input Offset Voltage vs. Power Supply Voltage. FIGURE 2-4: Input Offset Voltage vs. Output Voltage with VDD = 4.5V. FIGURE 2-5: Input Offset Voltage vs. Output Voltage with VDD = 45V. FIGURE 2-6: Input Offset Voltage vs. Common Mode Voltage with VDD = 4.5V FIGURE 2-7: Input Offset Voltage vs. Common Mode Voltage with VDD = 45V. FIGURE 2-8: CMRR. FIGURE 2-9: PSRR. FIGURE 2-10: DC Open-Loop Gain. FIGURE 2-11: CMRR and PSRR vs. Ambient Temperature. FIGURE 2-12: DC Open-Loop Gain vs. Ambient Temperature. FIGURE 2-13: Input Bias and Offset Currents vs. Common Mode Input Voltage with TA = +85°C. FIGURE 2-14: Input Bias and Offset Currents vs. Common Mode Input Voltage with TA = +125°C. FIGURE 2-15: Input Bias and Offset Currents vs. Ambient Temperature with VDD = 45V. FIGURE 2-16: Input Bias Current vs. Input Voltage (Below VSS). 2.2 Other DC Voltages and Currents FIGURE 2-17: Input Common Mode Voltage Headroom (Range) vs. Ambient Temperature. FIGURE 2-18: Output Voltage Headroom vs. Output Current. FIGURE 2-19: Output Voltage Headroom vs. Ambient Temperature. FIGURE 2-20: Output Voltage Headroom vs Temperature RL = 10 kΩ. FIGURE 2-21: Output Short Circuit Current vs. Power Supply Voltage. FIGURE 2-22: Supply Current vs. Power Supply Voltage. 2.3 Frequency Response FIGURE 2-23: CMRR and PSRR vs. Frequency. FIGURE 2-24: Open-Loop Gain vs. Frequency with VDD = 4.5V. FIGURE 2-25: Open-Loop Gain vs. Frequency with VDD = 45V. FIGURE 2-26: Gain Bandwidth Product and Phase Margin vs. Ambient Temperature. FIGURE 2-27: Gain Bandwidth Product and Phase Margin vs. Common Mode Input Voltage. FIGURE 2-28: Closed-Loop Output Impedance vs. Frequency with VDD = 4.5V. FIGURE 2-29: Closed-Loop Output Impedance vs. Frequency with VDD = 45V. FIGURE 2-30: Maximum Output Voltage Swing vs. Frequency. FIGURE 2-31: EMIRR vs. Frequency. 2.4 Input Noise FIGURE 2-32: Input Noise Voltage Density and Integrated Input Noise Voltage vs. Frequency. FIGURE 2-33: Input Noise vs. Time with 1 Hz and 10 Hz Filters and VDD = 4.5V. FIGURE 2-34: Input Noise vs. Time with 1 Hz and 10 Hz Filters and VDD = 45V. 2.5 Time Response FIGURE 2-35: Input Offset Voltage vs. Time with Temperature Change. FIGURE 2-36: Input Offset Voltage vs. Time at Power-Up. FIGURE 2-37: The MCP6V51 Shows No Input Phase Reversal with Overdrive. FIGURE 2-38: Noninverting Small Signal Step Response. FIGURE 2-39: Noninverting Large Signal Step Response. FIGURE 2-40: Noninverting 40 VPP Step Response. FIGURE 2-41: Inverting Small Signal Step Response. FIGURE 2-42: Inverting Large Signal Step Response. FIGURE 2-43: Inverting 40 VPP Step Response. FIGURE 2-44: Slew Rate vs. Ambient Temperature. FIGURE 2-45: Output Overdrive Recovery vs. Time with G = -10 V/V. FIGURE 2-46: Output Overdrive Recovery Time vs. Inverting Gain. 3.0 Pin Descriptions TABLE 3-1: Pin Function Table 3.1 Analog Output 3.2 Analog Inputs 3.3 Power Supply Pins 4.0 Applications 4.1 Overview of Zero-Drift Operation FIGURE 4-1: Simplified Zero-Drift Op Amp Functional Diagram. FIGURE 4-2: First Chopping Clock Phase; Equivalent Amplifier Diagram. FIGURE 4-3: Second Chopping Clock Phase; Equivalent Amplifier Diagram. 4.2 Other Functional Blocks FIGURE 4-4: Simplified Analog Input ESD Structures. FIGURE 4-5: Protecting the Analog Inputs against High Voltages. FIGURE 4-6: Protecting the Analog Inputs Against High Currents. EQUATION 4-1: EQUATION 4-2: 4.3 Application Tips EQUATION 4-3: FIGURE 4-7: Recommended RISO Values for Capacitive Loads. FIGURE 4-8: Output Resistor, RISO, Stabilizes Capacitive Loads FIGURE 4-9: Amplifier with Parasitic Capacitance. EQUATION 4-4: 4.4 Typical Applications FIGURE 4-10: Low-Side Current Sense for 1.5A Max Load Current. FIGURE 4-11: Simple Design. FIGURE 4-12: Higher Performance Design. FIGURE 4-13: RTD Sensor. 5.0 Design Aids 5.1 Microchip Advanced Part Selector (MAPS) 5.2 Analog Demonstration and Evaluation Boards 5.3 Application Notes 6.0 Packaging Information 6.1 Package Marking Information Appendix A: Revision History Revision A (December 2018) Product Identification System Trademarks Worldwide Sales and Service
