AXICOM IM RELAY SIGNAL RELAYS INSULATION DATAOTHER DATAStandard EU RoHS/ELV, China RoHS, CD, P, I2) REACH, Halogen content refer (Standard, (High current, to the Product Compliance Performance type (High Material compliance sensitive, ultra high contact Support Center at www. dielectric high sensitive stability te.com/customersupport/ version) version) version) rohssupportcenter 108-98001 Rev. M AXICOMÊSignalÊRelays Ambient temperature -40 °C to +85 °C IM Relay 2 Pole Changeover / 2 Form C / DPDT Initial dielectric strength Thermal resistance <150 K/W 108-98001 Rev. M between open Category of AXICOMÊSignalÊRelays 750 Vrms 1500 Vrms 750 Vrms Dimensions Dimensions in mm contacts environmental IM Relay 2 Pole Changeover / 2 Form C / DPDT RT V - hermetically sealed between contact protection 1800 Vrms 1800 Vrms 1500 Vrms IMÊTHT IMÊTHT IMÊSMT IMÊSMT and coil IEC 61810 Dimensions Standard Narrow GullÊWings Dimensions in mm J-Legs mm inch mm inch mm inch mm inch between adjacent Vibration r L esistance 10.00ʱÊ0.08 0.393ʱÊ0.003 10.00ʱÊ0.08 0.393ʱÊ0.003 10.00ʱÊ0.08 0.393ʱÊ0.003 10.00ʱÊ0.08 0.393ʱÊ0.003 1000 Vrms 1800 Vrms 750 Vrms W 6.00ʱÊ0.08 0.236ʱÊ0.003 20 g, 10 to 500 Hz 5.70ʱÊ0.30 0.224ʱÊ0.012 ÊÊ6.00ʱÊ0.08 0.236ʱÊ0.003 ÊÊ6.00ʱÊ0.08 0.236ʱÊ0.003 contacts (functional) H IMÊTHT 5.65ÊÐÊ0.20 0.222ÊÐÊ0.008 IMÊTHT 5.80ʱÊ0.08 IMÊSMT 0.230ʱÊ0.003 ÊÊ5.65ÊÐÊ0.20 IMÊSMT 0.222ÊÐÊ0.008 ÊÊ5.65ÊÐÊ0.02 0.222ÊÐÊ0.008 T Standard 3.2 0.125 Narrow 3.2 0.125 GullÊWings N/A N/AJ-Legs N/A N/A Shock resis mm T1 tance inch N/A mm N/A inch N/A mm N/A inch 7.50ʱÊ0.30 mm 0.295ʱÊ0.011 inch2.80ʱÊ0.20 0.110ʱÊ0.007 L 10.00ʱÊ0.08 T2 0.393ʱÊ0.003 5.08ʱÊ0.10 10.00ʱÊ0.08 0.200ʱÊ0.004 0.393ʱÊ0.003 3.20ʱÊ0.10 10.00ʱÊ0.08 0.126ʱÊ0.004 0.393ʱÊ0.003 5.08ʱÊ0.10 10.00ʱÊ0.08 0.200ʱÊ0.004 0.393ʱÊ0.003 5.08ʱÊ0.10 0.200ʱÊ0.004 (functional), half W 6.00ʱÊ0.08 D1 0.236ʱÊ0.003 3.20ʱÊ0.15 5.70ʱÊ0.30 0.126ʱÊ0.006 50 g 0.224ʱÊ0.012 3.20ʱÊ0.15 ÊÊ6.00ʱÊ0.08 0.126ʱÊ0.006 0.236ʱÊ0.003 3.20ʱÊ0.15 ÊÊ6.00ʱÊ0.08 0.126ʱÊ0.006 0.236ʱÊ0.003 3.20ʱÊ0.15 0.126ʱÊ0.006 H 5.65ÊÐÊ0.20 0.222ÊÐÊ0.008 5.80ʱÊ0.08 0.230ʱÊ0.003 ÊÊ5.65ÊÐÊ0.20 0.222ÊÐÊ0.008 ÊÊ5.65ÊÐÊ0.02 0.222ÊÐÊ0.008 D2 2.20ʱÊ0.15 0.087ʱÊ0.006 2.20ʱÊ0.15 0.087ʱÊ0.006 2.20ʱÊ0.15 0.087ʱÊ0.006 2.20ʱÊ0.15 0.087ʱÊ0.006 Initial surge withstand voltage sinus 11ms T 3.2 Tw 0.125 0.40 3.2 0.015 0.125 0.4 N/A 0.015 N/A0.4 N/A 0.015 N/A 0.4 0.015 T1 N/A N/A N/A N/A 7.50ʱÊ0.30 0.295ʱÊ0.011 2.80ʱÊ0.20 0.110ʱÊ0.007 S 0.75 0.029 0.30ʱÊ0.05 0.011ʱÊ0.002 N/A N/A N/A N/A T2 5.08ʱÊ0.10 0.200ʱÊ0.004 3.20ʱÊ0.10 0.126ʱÊ0.004 5.08ʱÊ0.10 0.200ʱÊ0.004 5.08ʱÊ0.10 0.200ʱÊ0.004 between open D1 3.20ʱÊ0.15 0.126ʱÊ0.006 3.20ʱÊ0.15 0.126ʱÊ0.006 3.20ʱÊ0.15 0.126ʱÊ0.006 3.20ʱÊ0.15 0.126ʱÊ0.006 1500 V 2500 V 1000 V Shock resistance contacts D2 2.20ʱÊ0.15 0.087ʱÊ0.006 2.20ʱÊ0.15 0.087ʱÊ0.006 2.20ʱÊ0.15 0.087ʱÊ0.006 2.20ʱÊ0.15 0.087ʱÊ0.006 (des THT Version SMT Version Tw tructiv 0.40 e), half 0.015 0.4 500 g 0.015 0.4 0.015 0.4 0.015 S 0.75 0.029 0.30ʱÊ0.05 0.011ʱÊ0.002 N/A N/A N/A N/A between contact sinus 0.5ms Standard Version Narrow Version Gull Wings J-Legs 2500 V 2500 V 2000 V and coil THT Version SMT Version Mounting position any between adjacent Standard Version Narrow Version Gull Wings J-Legs 1500 V 2500 V 1000 V Weight max. 0. 10.0±0.08 75 g contacts 10.0±0.08 6.0±0.08 5.7±0.3 10.0±0.08 6.0±0.08 10.0±0.08 6.0±0.08 Moisture sensitive level, JEDEC 0.75 0.3±0.05 10.0±0.08 5.65-0.2 6.0±0.08 J-STD-0 10.0±0.08 5.8±0.0820F MSL3 r 5.7±0.3 elated only 10.0±0.08 6.0±0.08 10.0±0.08 6.0±0.08 5.65-0.2 5.65-0.2 0.4 5.08±0.1 0.4 2.8±0.2 Initial insulation resistance 3.2 3.2 0.4 0.75 0.4 to SMT relays packed in orginal 7.5±0.3 0.3±0.05 5.08±0.1 R5.65-0.2esistance to 5.8±0.08 dry 5.08±0.1 -packs. Calculated shelf lif 3.2±0.1 5.65-0.2 5.65-0.2 0.4 e in 5.08±0.1 0.4 Coplanarity between insulated ≤0.1mm 3.2 Coplanarity ≤0.1mm 3.2 0.4 2.8±0.2 7.5±0.3 3.2±0.15 2.2±0.15 2.2±0.15 >10⁹ Ω >10⁹ Ω >10⁹ Ω soldering hea 0.4 t SMT 3.2±0.15 2.2±0.15 2.2±0.15 sealed bag: 36 months a 3.2±0.15 2.2±0.15 2.2±0.15 t <400C Coplanarity ≤ 0.1mm Coplanarity ≤ 0.1mm 3.2±0.15 2.2±0.15 2.2±0.15 elements 5.08±0.1 5.08±0.1 3.2±0.1 IEC 60068-2-58 and <90% relative humidity (RH). Coplanarity ≤0.1mm 3.2±0.15 2.2±0.15 2.2±0.15 Coplanarity ≤0.1mm 3.2±0.15 2.2±0.15 2.2±0.15 3.2±0.15 2.2±0.15 2.2±0.15 Coplanarity ≤ 0.1mm Coplanarity ≤ 0.1mm 3.2±0.15 2.2±0.15 2.2±0.15 Mounting Hole Layout Floor life (out of the bag) at Solder Pad Layout View onto the component side of the PCB (top view) View onto the component side of the PCB (top view) Capacitance Mounting Hole Layout assembly site is 168 Hours at ≤ Solder Pad Layout V 300C iew onto the component side of the PCB (top view) /60% RH. View onto the component side of the PCB (top view) between open Standard Version Narrow Version Gull Wings max. 1 pF contacts Ultrasonic cleaning not recommended Standard Version Narrow Version Gull Wings between contact Packaging/unit max. 2 pF and coil THT version tube/50pcs., box/1000 pcs. between adjacent max. 2 pF reel/1000 pcs., box/1000 contacts SMT version or 5000 pcs. ¯Êmin.Ê0.75 ¯Êmin.Ê0.75 ¯Êmin.Ê0.75 ¯Êmin.Ê0.75 2) this relay contains SF6 (Sulfur hexafluoride, CAS number: 2551-62-4) for dielectric Avoid using the relays under strong magnetic fields, as strength enhancement, SF6 is hermetically sealed in relay without leaks to air during electrical parameters will be affected, such as operate/set Terminal Assignment normal application as recommended per the applicable product specification. It is cla- Terminal Assignment rified that the usage of SF6 in mini signal relay is not prohibited by related regulations. voltage and release/reset voltage. Relay – top view Please contact TE local sales or field engineer for further information and detailed Relay – top view material declaration. To ensure the dielectric performance after soldering processes / MONOSTABLE VERSION Non-Latching Type BISTABLE VERSION, 1 C Latching Type, 1 Coil OIL assembly customer is advised to perform a dielectric test. Non-Latching Type Latching Type, 1 Coil REST CONDITIONRESET C r ONDITION not energized condition not ener reset condition gized condition eset condition RF DATA Isolation at 100MHz/900MHz 37.0 dB/18.8 dB Insertion loss at 100MHz/900MHz 0.03 dB/0.33 dB ContactsÊ inÊ resetÊ position.Ê ContactsÊ in ContactÊ Ê resetÊ position.Ê ContactÊ positionÊ mightÊ changeÊ duringÊ trans- positionÊ mightÊ changeÊ duringÊ trans- Voltage standing wave ratio portationÊ andÊ mustÊ beÊ resetÊ beforeÊ portationÊ andÊ mustÊ beÊ resetÊ beforeÊ 1.06/1.49 use. (VSWR) at 100MHz/900MHz use. Contacts are shown in reset condition. All specifications subject to change. Consult Tyco Electr C onics for latest specifications. ontact position might change during 5 of 28 All specifications subject to change. Consult T transporta yco Electronics for latest specifications. tion and must be reset before 5 of 28 use. INDUSTRIAL / AXICOM IM RELAY 4 Document Outline Introduction Features Applications Approvals Contact Data Max. DC load breaking capacity Coil Data Coil versions, standard version, monostable, 1 coil Coil operating range, standard version, monostable, 1 coil Coil versions, sensitive version, monostable, 1 coil Coil versions, ultra high sensitive version, monostable, 1 coil Coil operating range, sensitive and ultra high sensitive version, monostable, 1 coil Coil versions, standard version, bistable 1 coil Coil operating range, Standard version, bistable, 1 coil Insulation Data Other Data Monostable version rest condition Bistable version, 1 coil reset condition RF data Dimensions PCB layout Processing Packing Product code structure Product Selection Information
