Datasheet IM (TE Connectivity) - 3
ManufacturerTE Connectivity
DescriptionGeneral Purpose Signal Relay, DC, Polarized, Monostable, 2 Form C DPDT-CO, 2 A Contact Rating, 3 VDC Coil Voltage, 250 VAC Contact Voltage, Axicom IM
Pages / Page11 / 3 — AXICOM IM RELAY. COIL OPERATING RANGE,. COIL DATA. STANDARD VERSION, …
File Format / SizePDF / 3.2 Mb
AXICOM IM RELAY. COIL OPERATING RANGE,. COIL DATA. STANDARD VERSION, MONOSTABLE, 1 COIL. Coil operating range. IM Relay
AXICOM IM RELAY COIL OPERATING RANGE, COIL DATA STANDARD VERSION, MONOSTABLE, 1 COIL Coil operating range IM Relay
AXICOM IM RELAY
SIGNAL RELAYS
108-98001 Rev. M AXICOMÊSignalÊRelays Magnetic system Monostable, bistable
Coil voltage range 1.5 VDC to 24 VDC 3,4 3,2
140 mW coil
3
200 mW coil Rated
2,8 Coil Operating Range
U Rated Operate Release Coil
2,6
max. at 0A Coil coil
2,4
voltage voltage voltage resistance
U code power
2,2
max. at 0A VDC VDC VDC
Ω
±10%
/U nom
Umax. at 2x1A
2 U
mW
Unom = Nominal coil voltage 3.1,48 e [
U
50mW coil
max. 2x2A
3.2 100mW coil U 1,6
U Coil versions, standard version, monostable, 1 coil
max. = Upper limit of the operative range of oltag
max. at 2x2A
1, 3 4 Umax. at 2x1A the coil voltage (limiting voltage) when l V2. U 1, 8 2 oi max. at 0A 00 1.5 1.13 0.15 16 140 C
U Umax. at 2x1A
coils are continously energized 2.6 1
nom. nominal coil voltage
2.0,48
U
Umax.
op. min.
08 2.4 1.80 0.24 41 140 at 0A Uop. min. = Lower limit of the operative range of 2.0,26 the coil voltage (reliable operate voltage) 0, 2 4 01 3 2.25 0.30 64 140 0,2 1.8
Urel. min.
For latching relays Uset min. resp. U 0 max. at 2x2A 02 4.5 3.38 0.45 145 140 oltage [U/Unom] 1.6 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 100 110 120 Ureset min. 1.4 Ambient Temperature [ºC] 03 5 3.75 0.50 178 140 Coil V 1.2 Unom. nominal coil voltage Urel. min. = Lower limit of the operative range of 1 the coil voltage (reliable release voltage) 04 6 4.50 0.60 257 140
COIL OPERA
0.8
TING RANGE,
Uop min. 0.6 05 9 6.75 0.90 579 140
SENSITIVE AND UL
0.4
TRA HIGH SENSITIVE VERSION,
0.2 Urel. min. 06 12 9.00 1.20 1029 140
MONOSTABLE, 1 COIL
0 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 10 0 1 10 12 0 07 24 18.00 2.40 2880 200 Ambient Temperature [°C]
Coil versions, sensitive version, monostable, 1 coil
11 3 2.40 0.30 91 100 3.4 12 4.5 3.60 0.45 194 100 3.2 140mW coil 3 200mW coil 13 5 4.00 0.50 234 100 2.8 Umax. at 2x1A 2.6 16 12 9.60 1.20 1315 110 ] 2.4 Umax. at 0A nom 2.2 17 24 19.20 2.40 4120 140 U 2 max. at 0A 1.8
Coil versions, ultra high sensitive version, monostable, 1 coil
1.6 U 1.4 oltage [U/U max. at 2x2A 21 3 3.00 0.30 180 50 1.2 Unom. nominal coil voltage 1 22 4.5 4.50 0.45 405 50 Coil V 0.8 0.6 23 5 5.00 0.50 500 50 0.4 Urel. min. 0.2 26 12 12.00 1.20 2880 50 0 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 100 110 120 All figures are given for coil without pre-energization, at ambient temperature +23 °C Ambient Temperature [°C]
COIL OPERATING RANGE, Rated Set Reset Coil Rated coil STANDARD VERSION, BISTABLE, 1 COIL Coil voltage voltage voltage resistance power code VDC VDC VDC
Ω
±10% mW
3.4 3.2
Coil versions, standard version, bistable 1 coil
3 U 2.8 max. - 5%coil duty at Umax.-5%coil 40 1.5 1.13 -1.13 23 100 2.6 2x2A (100mW) duty at 0A(100mW) Umax. - 100% coil duty at 2.4 ] 0A (100mW) 48 2.4 1.80 -1.80 58 100 2.2 Umax.-5%coil nom 2 duty at 0A (200mW) 41 3 2.25 -2.25 90 100 1.8 Umax. - 100% coil duty at 1.6 0A (200mW) Umax. -5% coil 42 4.5 3.38 -3.38 203 100 1.4 duty at 2x1A (100mW) oltage [U/U 1.2 43 5 3.75 -3.75 250 100 1 Unom. nominal coil voltage Coil V 0.8 44 6 4.50 -4.50 360 100 0.6 Uset min. 0.4 45 9 6.75 -6.75 810 100 100 mW Latching 0.2 200 mW Latching 46 12 9.00 -9.00 1440 100 0 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 100 110 120 130 140 47 24 18.00 -18.00 2880 200 Ambient Temperature [°C] INDUSTRIAL /
AXICOM IM RELAY
3 All specifications subject to change. Consult Tyco Electronics for latest specifications. 24 of 28 Document Outline Introduction Features Applications Approvals Contact Data Max. DC load breaking capacity Coil Data Coil versions, standard version, monostable, 1 coil Coil operating range, standard version, monostable, 1 coil Coil versions, sensitive version, monostable, 1 coil Coil versions, ultra high sensitive version, monostable, 1 coil Coil operating range, sensitive and ultra high sensitive version, monostable, 1 coil Coil versions, standard version, bistable 1 coil Coil operating range, Standard version, bistable, 1 coil Insulation Data Other Data Monostable version rest condition Bistable version, 1 coil reset condition RF data Dimensions PCB layout Processing Packing Product code structure Product Selection Information
