Datasheet TZX (Vishay) - 4
| Manufacturer | Vishay |
| Description | Small Signal Zener Diodes in DO-35 (DO-204AH) package |
| Pages / Page | 7 / 4 — TZX-Series. ELECTRICAL CHARACTERISTICS. ZENER VOLTAGE. DYNAMIC. TEST … |
| File Format / Size | PDF / 125 Kb |
TZX-Series. ELECTRICAL CHARACTERISTICS. ZENER VOLTAGE. DYNAMIC. TEST CURRENT. REVERSE LEAKAGE CURRENT. RANGE. RESISTANCE. PART NUMBER
TZX-Series
(Tamb = 25 °C, unless otherwise specified)
ZENER VOLTAGE DYNAMIC TEST CURRENT REVERSE LEAKAGE CURRENT RANGE RESISTANCE PART NUMBER VZ at IZT1 IZT1 IR at VR IR at VR (1) ZZ at IZT1 V mA μA V μA V
Ω
MIN. MAX. MAX. MAX. MAX.
TZX22B 21.6 22.6 2 1 17 0.04 20.5 65 TZX22C 22.3 23.3 2 1 17 0.04 21.2 65 TZX24A 22.9 24 2 1 19 0.04 21.8 70 TZX24B 23.6 24.7 2 1 19 0.04 22.4 70 TZX24C 24.3 25.5 2 1 19 0.04 23.1 70 TZX24X 22.61 23.77 2 1 19 0.04 21.5 70 TZX27A 25.2 26.6 2 1 21 0.04 23.9 80 TZX27B 26.2 27.6 2 1 21 0.04 24.9 80 TZX27C 27.2 28.6 2 1 21 0.04 25.8 80 TZX27X 26.99 28.39 2 1 21 0.04 25.6 80 TZX30A 28.2 29.6 2 1 23 0.04 26.8 100 TZX30B 29.2 30.6 2 1 23 0.04 27.7 100 TZX30C 30.2 31.6 2 1 23 0.04 28.7 100 TZX30X 29.02 30.51 2 1 23 0.04 27.6 100 TZX33A 31.2 32.6 2 1 25 0.04 29.6 120 TZX33B 32.2 33.6 2 1 25 0.04 30.6 120 TZX33C 33.2 34.5 2 1 25 0.04 31.5 120 TZX36A 34.2 35.7 2 1 27 0.04 32.5 140 TZX36B 35.3 36.8 2 1 27 0.04 33.5 140 TZX36C 36.4 38 2 1 27 0.04 34.6 140 TZX36X 35.36 37.19 2 1 27 0.04 33.6 140
Notes
• Additional measurement of voltage group TZM9V1 to TZX36, IR at 95 % VZmin. ≤ 40 nA at Tj = 25 °C (1) Additional measurement
BASIC CHARACTERISTICS
(Tamb = 25 °C, unless otherwise specified) 500 600 500 ient (K/W) 400 b 400 300 300 nction Am l l u er Dissipation (mW) J w 200 200 Resist. 100 100 m. T = constant - Total Po L tot P Ther 0 0 - 0 40 80 120 160 200 A 0 5 10 15 20 thJ R 95 9602 T - Ambient Temperature (°C) I - Lead Length (mm) 95 9611 amb Fig. 1 - Thermal Resistance vs. Lead Length Fig. 2 - Total Power Dissipation vs. Ambient Temperature Rev. 2.7, 04-Jun-2024
4
Document Number: 85614 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
