You can realize a floating variable resistance, with hyperbolic taper, with this circuit. Note that fixed resistors with the same number are matched pairs
AuthorsTL Flaig
Main DocumentArticle «Synthesize Variable Resistors with Hyperbolic Taper»
DescriptionFigure 2
File Format / SizePDF / 19 Kb
You can realize a floating variable resistance, with hyperbolic taper, with this circuit Note that fixed resistors with the same number are matched pairs
