This design idea is primarily intended to depict a novel switch architecture that can cater to extended battery range coupled with robust protection and diagnostic strategies. It also uses only a single CPU pin-per-switch, as opposed to two CPU pins for l
AuthorsVishwas Vaidya
Main DocumentArticle «Automotive low side output switch architecture suitable for 8 to 48 volt buses and beyond»
DescriptionFigure 1
File Format / SizePDF / 16 Kb
This design idea is primarily intended to depict a novel switch architecture that can cater to extended battery range coupled with robust protection and diagnostic strategies It also uses only a single CPU pin-per-switch, as opposed to two CPU pins for l
