El.Components
ADC, DAC
Amplifiers
Capacitors
Discretes
Drivers
El.Comp.Tech.
Logic
MCU
MEMS
Memory
Optoelectron.
Processors
Program.Logic
RF
Sensors
El.Engineer.
Adv. Tech
Consumer Tech
Climate Tech
Communic.
Future Tech
Modified controller and controlled …
Modified controller and controlled with the digital and analog grounds of the controller tied together with a 1 Ω resistance between the two
John Dunn
Quelling a ground loop
Figure 4
10 Kb
Figure 2. Block diagram of the Bertan 200-C488 GPIB controller and the controlled Bertan 205A/210 high voltage power supply
Figure 3. Controller and controlled with a ground loop current whose current magnitude interfered with both control and monitoring
Figure 4. Modified controller and controlled with the digital and analog grounds of the controller tied together with a 1 Ω resistance between the two
Figure 5. Controller and controlled with a diminished ground loop current
