Simple circuit times bathroom fan
National Semiconductor LM2905
Maxwell Strange
EDN
Forget to turn off the ceiling fan in your bathroom? Install the simple timer in Figure 1. It's located out-of-sight in the fan unit, and you turn it on via the wall switch. The circuit costs virtually nothing, using "junk" parts. When ac power appears, a simple rectifier develops approximately 7 V across filter capacitor C. This voltage powers the LM2905 analog timer and simultaneously triggers it via trigger-input Pin 1; output Pin 7 then goes low, turning on the solid-state relay and fan. Low-leakage capacitor CT and resistor RT set the time delay; for the values shown, the delay is 1000 sec, or approximately 17 minutes. At time-out, Pin 7 goes high, turning off the relay. For most fans, this relay can be a small, pc-mountable unit rated at as little as 0.5 A ac load current. These relays typically turn on reliably at 3 V. You can use resistor R to drop excess voltage, thereby reducing loading on the power supply.
Figure 1. Gain control of your bathroom fan by using this simple time-out circuit.
The p-channel JFET turns on when the power switches off, rapidly discharging CT to allow immediate recycling. The 10-kW series resistor makes the circuit inherently safe; in a worst-case failure, line voltage appears across this resistor and develops a harmless 1.4 W. You can easily adapt this circuit to other applications. You can change the timing or make it linearly adjustable, and you can program the solid-state relay to turn on instead of off at time-out, by connecting Pin 8 of the timer to Pin 4 instead of Pin 2. You can also reverse the action of the solid-state relay by reversing the control inputs.
Materials on the topic
EDN
