News & Press Releases Linear Technology - 9
Manufacturer: "Linear Technology"
Search results: 93 Output: 81-90
  1. Linear Technology introduced a high accuracy temperature-to-voltage converter with built-in series resistance cancellation for 2.5 V to 5.5 V systems. Many low voltage systems today rely on temperature to assess overall system health and ...
    Jul 12, 2011
  2. Linear Technology announces the LT1999 , a high-voltage amplifier designed for bidirectional current sensing in the presence of fast switching common-mode voltages from -5V to 80V. This wide input common-mode range is obtained with standard low ...
    Apr 19, 2011
  1. Linear Technology announces the LT3799 , an isolated LED controller with active power factor correction (PFC), specifically designed for driving LEDs from a universal input range of 90VAC to 265VAC. The LTC3799 is optimized for LED applications ...
    Feb 22, 2011
  2. Designed to drive high-current LEDs at constant current, the H-grade version LT3517 LED drivers features a 3 to 30-V input voltage range with a transient protection to 40 V. The part operates with a junction temperature up to 150 C and can drive up ...
    Aug 3, 2010
  3. Fran Granville Linear Technology recently introduce the LTC3588-1 energy harvester, targeting low-energy sources, including piezoelectric transducers. The LTC3588-1 integrates a low-loss, full-wave bridge rectifier with a high-efficiency buck ...
    Jan 23, 2010
  4. Linear Technology announces the LT3760 , an 8-channel LED driver, utilizing a step-up DC/DC controller capable of driving up to a 45V string of 100mA LEDs per channel. Its internal 60V, 1MHz DC/DC boost mode controller is designed to operate as a ...
    Jan 6, 2010
  5. The LTC3553 a micropower multifunction PMIC features a pin-selectable standby mode that reduces battery drain current to 12 µA while keeping all outputs in regulation. It integrates a USB-compatible PowerPath manager, a stand-alone battery ...
    Dec 30, 2009
  6. Linear Technology 's LTC3813 is a synchronous No RSENSE step-up switching regulator controller that eliminates the boost diode and the heat sink normally required in medium to high power non-synchronous boost converters. The LTC3813 can regulate ...
    Jan 15, 2008
  7. Amplifiers Linear Technology LT6003 LT6004 LT6005
    The LT6003 / LT6004 / LT6005 from Linear Technology are single/dual/quad op amps designed to maximize battery life and performance for portable applications. These amplifiers operate on supplies as low as 1.6 V and are fully specified and ...
    Sep 6, 2007
  8. The LT3591 from Linear Technology is a fixed frequency step-up DC/DC converter specifi cally designed to drive up to ten white LEDs in series from a Li-Ion cell. Series connection of the LEDs provides identical LED currents resulting in ...
    Sep 3, 2007
Sort by: relevance / date
