El.Components
ADC, DAC
Amplifiers
Capacitors
Discretes
Drivers
El.Comp.Tech.
Logic
MCU
MEMS
Memory
Optoelectron.
Processors
Program.Logic
RF
Sensors
El.Engineer.
Adv. Tech
Consumer Tech
Climate Tech
Communic.
Future Tech
Datasheet MIA-M10Q (u-blox)
Datasheet MIA-M10Q (u-blox) - 10
Michael O'loughlin
Shunt regulator eases power-supply-start-up woes
Manufacturer
u-blox
Standard precision GNSS module
Pages / Page
23
10
2
3
8
9
10
2
3
8
9
10
Figure 1. An uncomplicated block diagram (a) conceals the TL431's internal complexity, but you need only three external resistors to use the TL431 in a basic shunt-regulator circuit (b)
Figure 2. An auxiliary winding supplies power to the supply's PWM controller
Figure 3. In this improved design, pulse-width-controller IC
1
derives its power from R
T
for start-up, auxiliary winding W
AUX
for normal operation, and shunt-regulator circuit IC
2
and Q
1
for low-load operation
Standard precision GNSS module. Datasheet MIA-M10Q
MIA-M10
MIA-M10Q-00B-01
