El.Components
ADC, DAC
Amplifiers
Capacitors
Discretes
Drivers
El.Comp.Tech.
Logic
MCU
MEMS
Memory
Optoelectron.
Processors
Program.Logic
RF
Sensors
El.Engineer.
Adv. Tech
Consumer Tech
Climate Tech
Communic.
Future Tech
Two power sources with …
Two power sources with diodes in the power path to power an application
Frederik Dostal
Robust power source with ideal diodes
Figure 1
9 Kb
Figure 1. Two power sources with diodes in the power path to power an application
Figure 2. Two ideal diodes provide higher efficiency and enable additional functions
Figure 3. Two ideal diodes with power source selection independent of the respective value of the voltage sources
