El.Components
ADC, DAC
Amplifiers
Capacitors
Discretes
Drivers
El.Comp.Tech.
Logic
MCU
MEMS
Memory
Optoelectron.
Processors
Program.Logic
RF
Sensors
El.Engineer.
Adv. Tech
Consumer Tech
Climate Tech
Communic.
Future Tech
Inductor current waveform
Abe Ibraheim, Kenneth Armijo, Piyu Dhaker
Analysis of switch-mode power supply and rectification: Sense resistor violations
Figure 3
7 Kb
Figure 1. A simplified schematic demonstrating the basic operation of buck converters and their feedback system. This diagram can be found in application note (
Figure 3. Inductor current waveform
Figure 4. Load regulation for an oversized sense resistor. This specific DC-to-DC converter is rated up to 15 A but stops regulating at around 4 A with an oversized sense resistor
Figure 5. This is an example of a proper Kelvin connection
Figure 7. Load regulation of the power supply when the filter compensation system is removed. This specific device is rated up to 15 A but stops regulating at 12 A
Figure 8. Suggested filter compensation RC specifications. Obtained from LTC3855 data sheet
