Auto-Audio
Bad Prescript
Music
You can use a …
You can use a generic level shifter to offset negative input levels (relative to J2) to positive-only at J1
∑-∆ Isolation amplifier transfers low frequencies across barrier
Figure 2
8 Kb
Figure 1. The floating sigma-delta converter U1 generates a pulse train whose duty cycle depends on the voltage at J1 and J2. The filtered DC level is reconstructed at the output J3
Figure 2. You can use a generic level shifter to offset negative input levels (relative to J2) to positive-only at J1
