Long leads to a PRTD can cause offset errors. Using a 4-wire Kelvin arrangement minimizes these. If the µC's A-D has external reference-voltage pins, they can be driven from the circuit for (notionally) improved accuracy
AuthorsNick Cornford
Main DocumentArticle «Dropping a PRTD into a thermistor slot - impossible?»
DescriptionFigure 5
File Format / SizePDF / 25 Kb
Long leads to a PRTD can cause offset errors Using a 4-wire Kelvin arrangement minimizes these If the µC's A-D has external reference-voltage pins, they can be driven from the circuit for (notionally) improved accuracy
