NewsArticlesBiblioCircuitsDatasheetsSitesDevicesPrices
News Articles Biblio Datasheets Sites Devices
e-Newsletter Subscription Authors
About usFor Authors Cooperation Advertising Contacts
Radiolocman.com - All about electronics
Analog DesignAntiqueApp NotesArduinoAudioAuto-AudioAutomationAutomotiveBad PrescriptBeginnersCAD & SoftCamcordersCellularComputers &DigitalDomesticGamesHigh VoltageInterfacesLaserLightMCU UsageMeasurementMedicineMonitorsMusicNetworksOscillatorsPCBPlatformsPowerRC ModelingRadioRobotsSatelliteSecuritySolarSupplyTVTelephoneTheoryTools and TecVideoWind EnergyWireless
Lingxing Mic…
CircuitsOscillators Beginners
CMOS Schmitt trigger IC …
CMOS Schmitt trigger IC makes VCO
Nov 24, 2025
Lingxing Microelectronics CD4584
David A. Johnson
By changing the supply voltage fed to a classic 4584 Schmitt trigger type oscillator, the oscillator frequency can be changed over a range of 50:1. A 74HCU04 inverter is used at the output of the 4584 to maintain a constant TTL logic level signal.
ГУН на КМОП триггере Шмитта
Materials on the topic
  1. Datasheet Texas Instruments CD4069UB
  2. Datasheet Lingxing CD4584
discovercircuits.com
Related publications
  • Circuits Schmitt trigger uses two transistors
  • Circuits Adaptive Schmitt trigger tames unruly signals
  • Circuits Schmitt trigger adapts its own thresholds
  • Articles Add a Schmitt-trigger function to CPLDs, FPGAs, and applications
  • Circuits Simple changes improve Schmitt trigger
  • Microcontrollers
  • e-Newsletter Subscription
  • Contacts
  • Privacy Policy
  • Change Privacy Settings
