RePlay XD720: the smallest easiest way to replay it
RePlay Replay XD720
Capturing action-packed HD Video is now easier and more affordable than ever, thanks to the new Replay XD720. Less than a year after launching the world’s smallest and lightest HD Action Sports Camera, the XD1080, the engineers at RePlay XD have created a new, smaller, lighter camera packed with features and an easy-to-use consumer-friendly interface.
Replay - Replay XD720
The XD720 captures color rich 720P HD at 30/60 frames per second. The system packs a non-fisheye, non-distorted 120 degree field of view lens and 5-megapixel image sensor. The sleek two ounce camera is about the size of a tube of lip balm and features a water-resistant, rugged aluminum housing that can withstand everything from extreme sports to hardcore motorsports and is packed with external audio line-in and is compatible with virtually all the RePlay XD Pro level mounts and accessories.
In addition to the camera’s best-in-class onboard mic, the Replay XD720 also has a secondary audio input that allows users to feed audio from their own source such as race radios, iPods and more. The camera records up to 130 minutes of video on a single charge of its internal Li-Ion battery. It includes a 4GB micro SD card and supports up to 32GB cards. The system remembers and holds settings, even when the battery runs down. and a “Quick-Clip” function allows editing in the field.
The Replay XD720 is incredibly easy to use. Simply flip a switch on the back to select frame rate and audio input options, and then replace the cap – it’s that easy. The Power and Record buttons require one simple touch, with specific vibration feedback and indicator lights for each command.
The XD720 kit includes the camera, a microfiber protective pouch, ballistic carrying case, 4GB micro SDHC card, USB charge / data cable, Micro USB card reader, micro SD to SD card adaptor, Car power Adapter, safety leash, and two mounting options. The RePlay XD exclusive mounts include a HeimLock, LowBoy and SnapTrays. Unlike other bulky POV cameras, the RePlay XD720’s small shape allows it to hide just about anywhere.
Key features
  • Smallest, lightest HD Camera on the market – about the size of a tube of lip balm, small enough to mount to your sunglasses.
  • Easy to use controls, limitless mounting options, rugged aluminum construction, water resistant.
  • hoots 720P HD footage at 30 or 60 frames per second, up to 2 hours of record time, up to 32GB micro SD.
  • Sound options include onboard mic and audio input for secondary microphones or radio input and more.
  • Replaces ever popular standard definition RePlay XD480 camera in line-up.
MSRP: $199.99
replayxd.com
