CSR making it far easier for device manufacturers to deliver multi-room networked home audio products thanks to the VibeHub platform, launched at CES 2014. The platform, available now to developers, will enable consumers to enjoy synchronised multi-room audio around the home using its SyncLock technology. This technology enables products to take content from any local or cloud-based source and create an unparalleled multi-room audio experience over an existing home Wi-Fi network.
The VibeHub platform gives developers a way to create whole home audio systems that are quick and easy to bring to market. CSR’s industry proven technology can be easily integrated and gives developers flexibility to differentiate their designs and determine the end-user experience.
The fully featured VibeHub platform can be used to build wireless speakers, intelligent audio adaptors, networked audio amplifiers and a wide range of other consumer audio products. These devices can simultaneously pull content from multiple sources including digital media servers, Internet radio or cloud services and distribute around the home autonomously. VibeHub’s extensible networking capabilities enable interoperability with a wide range of today’s popular wireless streaming protocols, including Apple’s AirPlay, which means that consumers aren’t limited to buying into a specific ecosystem.
The platform’s Bluetooth® capabilities enable consumers to stream audio from a wide range of mobile devices, making it easy to share music over the home network to any room without the Bluetooth audio source device having to join the home Wi-Fi network.
Key features
- Access point agnostic: VibeHub does not rely on special features in a home’s access point so there is no need for end users to purchase additional equipment
- Most extensive connectivity functionality: The SyncLock technology inside VibeHub enabled products allows for more connectivity options than any other solution on the market, including Bluetooth, Bluetooth Smart, 802.11n, Ethernet, SPDIF as well as analogue jacks
- Interoperability with a wide range of devices:Common music sources including Windows PC, Android, as well as Apple iOS and OSX devices are interoperable. The system allows bridging into a network via existing protocols which lowers the cost of entry for the consumer as they can use existing music sources in the home
- Consumer experience: The VibeHub takes advantage of CSR aptX coding technologies for high-quality audio over a Bluetooth connection and a higher bitrate version with forward error correction (FEC) for IP networks. This high quality IP network variant is supported by SyncLock technology, which has been developed for broadcast Audio Over IP applications. SyncLock distributes audio over the network and enables tight synchronisation between speakers, meaning there is no noticeable time-lapse experienced by listeners in different rooms. The system can also support multi-user scenarios, giving users the option to listen to different music in different rooms, from a variety of different sources
- Intuitive system control: CSR has developed Android and iOS apps to control the system which can be easily reskinned by end brands to fit with their look and feel. Many controllers can be used concurrently, enabling a true multi-user, multi-room audio experience
