VLSI Solution announces VS1073, the world's most advanced audio codec coprocessor with earphone amplifier.
The VS1073 IC is a low-power mixed-signal audio coprocessor that can encode and decode a myriad of different formats. It can greatly lower the workload of a system microcontroller, freeing its time for other operations like communicating over Wi-Fi or Ethernet. To better connect with the outside world, VS1073 contains both a high-quality stereo ADC and DAC, along with an earphone amplifier capable of driving a 30-ohm load, and a 32-bit I2S digital output.
From a hardware point of view VS1073 is a pin-compatible replacement for VLSI Solution's best-selling VS1053b and VS1063a audio coprocessors, except for the core voltage, lowered from 1.85 V to 1.25 V, and contributing to a lowered total power consumption. This lower voltage is made possible by a new manufacturing process, also making it possible to maintain longevity of the chip supply, always a priority of VLSI.
VS1073 can decode MP3, MP2, Ogg Vorbis, FLAC, ALAC, Ape, AAC, DSD, Opus, WMA, AC-3, WAV, and AIFF files. It can encode MP3, Ogg Vorbis, FLAC, WAV PCM / ADPCM, G.711 or G.722. There is also a full-duplex codec mode that can handle PCM, IMA ADPCM, G.711 and G.722.
VS1073 provides a 5-band equalizer, and sound effects like a speed shifter and VLSI Solution's proprietary EarSpeaker headphone processing. It is also possible to mix PCM sound effects or audio from a stereo analog input on top of playback audio.
All these features, combined with CD-quality Analog-to-Digital and Digital-to-Analog signal path performance as well as the 30-ohm earphone amplifier, make VS1073 the first choice for a wide range of consumer and industrial applications.
VS1073 is offered in the familiar LQFP-48 7×7×1.4 RoHS compatible package.
