Toshiba introduces 40V / 2.0A constant-current stepper motor driver IC
Toshiba TB67S531FTG
Phase input interface design improves noise immunity to prevent step-out, enabling stable and reliable control in demanding industrial environments
Toshiba Electronics Europe announces the launch of the TB67S531FTG, a constant-current, two-phase bipolar stepper motor driver IC. The device delivers stable and reliable motor control especially in electrically noisy industrial environments. Intended applications include industrial, commercial, and office equipment including sewing machines, surveillance cameras, printers, and scanners.
Toshiba - TB67S531FTG
The TB67S531FTG features a phase input interface that controls motor current in each phase. This approach minimizes unintended step transitions and helps prevent motor step-out when operating in electrically noisy environments.
Rated for motor output voltages of up to 40 V and currents of up to 2.0 A, the device supports robust motor drive capability. Its low on-resistance (RDS(ON)) of 0.8 Ω (typ.) reduces heat generation, enhancing system efficiency and thermal performance. To simplify system design and reduce component count, the TB67S531FTG integrates key functions, including a current detection circuit for constant-current control and a charge pump circuit for driving the H-bridge output stage. It is housed in a compact 5.0 mm × 5.0 mm QFN32 package.
The device supports multiple excitation modes, from full-step to quarter-step, enabling flexible motor control based on application requirements. In addition, built-in protection features such as thermal shutdown, over-current detection, and under-voltage lockout enhance system safety and reliability.
