El.Components
ADC, DAC
Amplifiers
Capacitors
Discretes
Drivers
El.Comp.Tech.
Logic
MCU
MEMS
Memory
Optoelectron.
Processors
Program.Logic
RF
Sensors
El.Engineer.
Adv. Tech
Consumer Tech
Climate Tech
Communic.
Future Tech
This GSM digital cellular …
This GSM digital cellular method shows how up to eight users can share a 200-kHz channel in different time slots within a frame of 1248 bits
Lou Frenzel
Fundamentals of communications access technologies: FDMA, TDMA, CDMA, OFDMA, AND SDMA
Figure 3
8 Kb
Figure 1. FDMA divides the shared medium bandwidth into individual channels. Subcarriers modulated by the information to be transmitted occupy each subchannel
Figure 2. This T1 digital telephony frame illustrates TDM and TDMA. Each time slot is allocated to one user. The high data rate makes the user unaware of the lack of simultaneity
Figure 3. This GSM digital cellular method shows how up to eight users can share a 200-kHz channel in different time slots within a frame of 1248 bits
Figure 4. Spread spectrum is the technique of CDMA. The compressed and digitized voice signal is processed in an XOR logic circuit along with a higher-frequency coded chipping signal. The result is that the digital voice is spread over a much wider bandwidth that c
Figure 5. OFDMA assigns a group of subcarriers to each user. The subcarriers are part of the large number of subcarriers used to implement OFDM for LTE. The data may be voice, video, or something else, and it's assembled into time segments that are then transmitted
Figure 6. SDMA separates users on shared frequencies by isolating them with directional antennas. Most cell sites have three antenna arrays to separate their coverage into isolated 120° sectors (a). Adaptive arrays use beamforming to pinpoint desired users whil
