Circuits & Schematics: -Wire Barometer 5/10 Volt Design vrs - 10
Search for: "-Wire Barometer 5/10 Volt Design vrs"
Search results: 1,300 Output: 91-100   Including: Design (1075); Wire (289); Volt (116); 510 (26); Barometer (3); vrs (0).
  1. Jim McLucas
    Circuits Measurement Texas Instruments CD74HC14 SN74LVC1G14 74LVC1G74 TLA431 TLV9162
    .. sensitivity of the circuit to minute changes in the input voltage. The sensitivity is 100 MHz per 5 volts, i.e., 20 MHz per volt. That means a 1-mV change on the input results in a 20-kHz change in the output frequency! So, how do you supply ...
    .. a PCB, purchased the (mostly) surface-mount components, loaded and re-flow soldered them onto the PCB, and then tested the design. Figure 1. VFC design that operates from 100 kHz to beyond 100 MHz with a single 5-V supply, providing ...
    Nov 14, 2025
  1. Stephen Woodward
    .. loop current. Set input = 20.00 mA. Adjust R2 for 20.00 mA loop current. Done. The input voltage burden is a negative 1.0 volt. The output loop voltage drop is 4 volts minimum to 40 volts maximum. The maximum ambient temperature (with no U1 ...
    .. Design Idea (DI) offers an alternative solution for an application borrowed from frequent DI contributor R. Jayapal, ...
    Dec 6, 2025
  2. Stephen Woodward
    .. were both absolutely correct. Table 6.6 in the TL431 datasheet reveals a maximum reference-voltage error of up to 2 mV per volt of cathode-to-anode voltage swing, consistent with the mediocre 20 V/40 µA = 500k active impedance he ...
    .. is to say, just how “constant” is their output held against changes in applied voltage? Frequent and expert Design Idea (DI) commentator Ashutosh Sapre was kind enough to measure this parameter for a design of mine and share ...
    Feb 5, 2026
  3. .. spaces between the LED spiral arms. Here you can see all the ladders in place and the opposing LED arms wired across with wire-wrap type wire (does anyone use wire-wrap anymore??) Because this circuit was intended to be potted in epoxy, all ...
    .. newer type high intensity LEDs (3000 - 5000mcd) were used along with a very simple discrete transistor drive circuit. The design goals included small size and excellent portability, as well as long battery life. To begin, the required ...
    Nov 13, 2008
  4. Tom Hornak
    .. 1. Pushing the on switch S 1 or S 2 for approximately 1 sec inserts the 12 V zener diodes D 1 or D 2 in series with the hot wire of the power line. During the push, the polarity-dependent conduction of the zener diodes creates a small ...
    .. guarantees that the flip-flops' Reset does not release before V DD reaches its full value. Note that you can use this Design Idea in other applications. For example, if you omit the circuit in Figure 3, the transitions in V 3 and V 4 ...
    Nov 3, 2022
  5. .. you need a $5.29 snap-on EMI suppressor from radio shack, part number 273-105, and you need some 18-20 gauge magnet wire (enamel-insulated copper wire). The magnet wire at radio shack is too small, you'll have to look elsewhere. ...
    .. Box, so now it's basically just a fun experiment that I did to explore the world of switching converters. That is the design I am going with for my system, since the parts are cheap and more easily available. While based on a more ...
    Oct 16, 2007
  6. .. the one on the left should have its positive side up. You can't see from this image, but you also need to solder a piece of wire between the two battery contacts on the opposite side of the board as well. The PIC is soldered to the PCB on the ...
    .. well. You can of course use a specialised PCB package, but I wanted an unusual cursive font on mine, so just hand-drew the design on a graphics package. This allowed me to incorporate my name into the actual circuit board - the electric ...
    Dec 11, 2007
  7. .. the battery's charge capability, you can send the data to a host processor or another destination through a single-wire interface, SPI, I2C, CAN (controller-area-network), or another industry-standard method. To maximize battery ...
    .. a positive-charging current. The outputs of both op amps are positive and range from 0 to approximately 5 V and simplify design of the interface with the ADC's multiplexed inputs. Using Texas Instruments' TLC27 7 for IC2 offers the ...
    Jan 21, 2008
  8. .. a lip around them, as this will hide an oversize or roughly-cut hole in either the plastic box or the transparency. Now you wire up your components / circuitry etc. Can't tell you how to do this, as it will depend on what you're building! ...
    .. image, you can see that each of these has a front panel area that is recessed by a fraction of an inch. Use a program to design the front panel overlay - I use Adobe Illustrator, but that is not the easiest to use (or the cheapest). ...
    Feb 4, 2008
  9. .. 4 or 8 MHz Oscillator SPST Switch 1µF Capacitor 30 pin SIPs 5 x 74LS373 Latches Prototype Board Solder 36 x LEDs Wire 30 AWG (aka Wirewrap) Wirewrap Tool Soldering Iron Parts List Details You may or may not be familiar with the ...
    .. The schematic for this project is much more complicated than previous projects. There are four main features in our design. (1) We will be able to program the pic on the board we develop. (2) We will be controlling a servo. (3) We ...
    Feb 28, 2008
Sort by: relevance / date
Search "-Wire Barometer 5/10 Volt Design vrs" on other search engines: Only-DataSheet.com Google
