Pin-Compatible, Low-Power ADCs Available in 80, 105 and 125 MSPS
May 26, 2004 - Building upon the high-performance analog design expertise showcased in the ADS5500 14-bit, 125-MSPS (mega samples per second) data converter, Texas Instruments Incorporated (TI) announced five new members of the ADS5500 high-speed analog-to-digital converter (ADC) family. The ADS5500 family now consists of three 14-bit ADCs and three 12-bit ADCs available in speeds of 80, 100 and 125 MSPS featuring exceptional spurious-free dynamic range (SFDR), high signal-to-noise ratio (SNR) and low power. (See www.ti.com/sc04119.)
The 14-bit ADS5541 combines high performance (71 dB SNR) at high speed (105 MSPS) with half the power (710mW) of competitive devices, while the 14-bit ADS5542 provides an economical 80-MSPS device with low power (670mW) and excellent high-frequency performance.
The ADS5520 (12-bit, 125 MSPS) and the ADS5521 (12-bit, 105 MSPS) deliver the highest signal accuracy and precision with an unmatched 69 dB SNR at 100 MHz input frequency (IF). The ADS5522 (12-bit, 80 MSPS) offers an even higher SNR of 70 dB. In addition, the 12-bit devices offer the lowest power dissipation for any 12-bit ADC at the 105 and 125 MSPS nodes.
The ADS5500 family is optimized to work with TI's high-performance C6000TM DSP platform, which is used in applications ranging from third-generation wireless communications infrastructure to high-resolution medical imaging. TI also has a range of amplifiers, such as the recently announced OPA695 1.4 GHz current-feedback amplifier, that are well suited to work with the ADS5500 family of data converters to achieve highest performance.
Equipment manufacturers can capitalize on the performance of the ADS5500 family to achieve a wide range of benefits, such as improved receiver performance in wireless communications, higher quality imaging in video systems, extended signal analysis capabilities for test equipment, and more precise analysis in medical instrumentation.
The low power dissipation reduces power supply requirements and the need for thermal management (cooling), resulting in smaller footprint and equipment size, higher circuit density and reduced system cost. The power savings also enables next-generation, high-performance portable wireless, test and measurement and video imaging systems.
Availability and Packaging
The five new members of the ADS5500 family are sampling now, with volume production scheduled for 3Q 2004. All devices are available in 64-TQFP PowerPadTM packages. Evaluation modules (EVMs) are also available.
