Littelfuse expands magnetic sensor portfolio with ultra-low-power omnipolar TMR switches
Littelfuse LF21173TMR LF21177TMR
Littelfuse, Inc. announced the launch of two next-generation omnipolar magnetic switches, the LF21173TMR and LF21177TMR. These devices combine Tunneling Magnetoresistance (TMR) and CMOS technologies in a compact LGA4 package, providing ultra-low power consumption, exceptional magnetic sensitivity, and fast response for compact, battery-powered systems.
Littelfuse - LF21173TMR, LF21177TMR
Designed for operation across a wide voltage range (1.8 V–5.5 V), the LF21173TMR and LF21177TMR support multiple magnetic thresholds, enabling flexible integration into space-constrained applications such as smart meters, electronic locks, medical devices, and portable consumer electronics. Compared with conventional Hall-effect switches, these TMR devices deliver significantly higher sensitivity and lower power draw, helping engineers build smaller, more energy-efficient, and longer-lasting products.
TMR advantage
Unlike traditional hall-effect technology that relies on the hall voltage generated by magnetic flux, TMR sensors measure resistance changes in magnetic tunnel junctions, producing stronger signal output at much lower current levels. The result is a switch that consumes less power while maintaining excellent accuracy and thermal stability – ideal for energy-constrained applications where every microamp counts.
At-a-glance: Key features and benefits
  • Ultra-low power consumption extends battery life in portable devices.
  • High magnetic sensitivity (9 – 30 Gauss) ensures reliable detection with smaller magnets.
  • Wide 1.8 V–5.5 V operating range supports flexible system integration.
  • Fast response time enables precise, real-time sensing.
  • Compact LGA4 package fits space-constrained designs.
  • Omnipolar operation detects both the north and south poles, simplifying the layout.
Markets and applications
  • Health care: continuous glucose monitors and drug delivery pens
  • Building automation: smart gas and water meters
  • Consumer electronics: robotic appliances and portable devices
  • Industrial automation: industrial controls and electronic locks
  • Transportation: e-bikes, two-/three-wheelers, and off-highway vehicles
