El.Components
ADC, DAC
Amplifiers
Capacitors
Discretes
Drivers
El.Comp.Tech.
Logic
MCU
MEMS
Memory
Optoelectron.
Processors
Program.Logic
RF
Sensors
El.Engineer.
Adv. Tech
Consumer Tech
Climate Tech
Communic.
Future Tech
Using an external DAC …
Using an external DAC (MAX5362) controlled by the Arduino Nano to provide more reference levels
Damian Bonicatto, Phoenix Bonicatto
Adaptive resolution for ADCs
Figure 4
11 Kb
Figure 1. Sample inductor voltage versus time curve for a circuit measuring the voltage across an inductor when a DC step voltage is applied through a series resistor. Note the flat slope after 3 seconds, which will increase the relative error of the measurement
Figure 2. Change in adaptive resolution using the Microchip ATmega328P's internal ADC with either reference V
CC
voltage of 5 V or internal reference of 1.1 V
Figure 3. This code continuously reads the ADC connected to analog pin A0. If A0 voltage < 1.1 V, the ADC reference is switched to 1.1 V. If A0 > 1.1 V, the ADC reference is switched to V
CC
Figure 4. Using an external DAC (MAX5362) controlled by the Arduino Nano to provide more reference levels
Figure 5. Using the Arduino Nano's PWM output and a lowpass filter to obtain the desired DC signal to use as a voltage reference
Figure 6. Using a resistor ladder and an analog switch, e.g., TI TMUX1204, to select different nodes on the ladder to generate tailored voltage reference values
