El.Components
ADC, DAC
Amplifiers
Capacitors
Discretes
Drivers
El.Comp.Tech.
Logic
MCU
MEMS
Memory
Optoelectron.
Processors
Program.Logic
RF
Sensors
El.Engineer.
Adv. Tech
Consumer Tech
Climate Tech
Communic.
Future Tech
Jig for testing the …
Jig for testing the noise characteristics of NPN transistors with reverse-biased base-emitter junctions
Christopher Paul
A non-finicky, mass-producible audio frequency white noise generator
Figure 3
9 Kb
Figure 2. The general form of an MLS generator. A reference lists a table of 2 to 5 specific taps for register lengths from N = 2 to 32 to produce repeating sequences of length 2
N
-1. Register initialization must include at least one non-zero value. The a
Figure 3. Jig for testing the noise characteristics of NPN transistors with reverse-biased base-emitter junctions
Figure 5. The equivalent input noise and test circuit for the TLVH431B (Figure 5-9 in the part's datasheet)
Figure 6. The test jig for TLVH431B spectral noise. There was no significant difference in the results shown in Figure 7 when values of 1 kΩ and 10 kΩ were used for R. 100 kΩ and 1 MΩ resistances supplied insufficient currents for the devices' operation
