Fully integrated protected GaN ICs with bi-directional loss-less current sensing delivers 4% higher efficiency, 15% lower system cost 40% smaller footprint. Navitas Semiconductor has announced a new family of GaNSense Motor Drive ICs targeting home ...
Vishay Intertechnology introduced the industry’s first AEC-Q100 qualified rectangular ambient light sensor. The Vishay Semiconductors VEML4031X00 features an ALS and highly sensitive IR photodiode in an opaque 4.38 mm by 1.45 mm surface-mount ...
Integrated low-power analog peripherals reduce design costs and complexity Devices designed for capturing rapidly changing analog signals must respond quickly while consuming minimal power, especially in battery-operated applications. To address ...
Manufacturers of cutting-edge audio equipment constantly seek to enhance sound quality while also meeting the growing demand for compact, lightweight, more integrated, and energy-efficient designs. At the same time, they must ensure seamless ...
Texas Instruments (TI) introduced the world's smallest MCU, expanding its comprehensive Arm Cortex-M0+ MSPM0 MCU portfolio. Measuring only 1.38 mm 2 , about the size of a black pepper flake, the wafer chip-scale package (WCSP) for the ...
STMicroelectronics has introduced the Teseo VI family of global navigation satellite system (GNSS) receivers aimed at high-volume precise positioning use cases. For the automotive industry, Teseo VI chips and modules will be core building blocks of ...
Vishay Intertechnology introduced two new IGBT and MOSFET drivers in the compact, high isolation stretched SO-6 package. Delivering high peak output currents of 3 A and 4 A, respectively, the Vishay Semiconductors VOFD341A and VOFD343A offer high ...
Toshiba Electronics Europe introduces the TB67S559FTG 50 V/3.0 A stepper motor driver IC that supports constant current control with built-in current detection. Housed in a 5.0 mm × 5.0 mm QFN32 package, the TB67S559FTG operates over a wide ...
Murata announces the development of the world’s smallest class 006003-inch size (0.16 mm × 0.08 mm) chip inductor. This achievement represents a volume reduction of approximately 75% compared to the smallest 008004-inch size (0.25 mm ...
